Author Topic: Real OEM and the R65LS  (Read 1139 times)
plc
« on: May 23, 2008, 05:17:24 PM »
Hi All,
I am having problems with Real OEM and wonder if anyone can help. I cannot see the R65LS in the menus of motorcycles available.  Moreover when I put in my VIN number it doesn't work.  Has anyone else had problems find the R65LS in Real OEM?
All the best,
Paul
Re: Real OEM and the R65LS
« Reply #1 on: May 23, 2008, 05:44:51 PM »
Paul,
Heres the path to take, click on each & you should find it
MOTORCYCLE --> ARCHIVE --> R45-R65LS..78-85 --> N/A --> R65LS --> EUROPE --> [select your date of manufacture] and Bobs yer Uncle! My Manufacture date is 01/1982 so I wind up here: http://www.realoem.com/bmw/partgrp.do?model=0359&mospid=47852
If you are still having trouble figuring out the build date try
http://bmbikes.co.uk/chassispages/enginechassis650.htm
And if all else fails PM me the VIN. Even if its recorded incorrectly I can figure it out. Long story involving state inspectors and modulo calculations.
« Reply #2 on: May 23, 2008, 07:28:05 PM »
Is the VIN of your frame and engine the same, and which are you using ?
The frame VIN is the 'controlling' number.
plc
« Reply #3 on: May 23, 2008, 08:23:20 PM »
Thanks Rich and Bob I have found my R65LS in Real OEM. I was failing to click Archive.
I needed the part number for the rear fuel tank clip. A cable tie is currently holding the tank in place. I went over a speed hump a little quick and felt the tank move.
Whenever I see a parts fiche I ponder over buying a new LS fairing and instrument panel.  Mmmmm maybe one day.
Thanks again,
Paul
