Author Topic: sign from above????  (Read 3383 times)
milkman
sign from above????
« on: October 30, 2007, 04:00:37 AM »
G'day again.
I have been off this forum for a while now, because they changed our security settings on the work server, and for some reason, this domain wouldn't work?? Must have thought R65'ers were dodgy.
Anyway, I've put some serious km's on my LS int he past year, stress free, until a fortnight ago (i posted about this elsewhere).
I am nearing my wits end, chasing this gremlin from my bike. I was contemlating selling  it once I get it fixed again, cursing so called german reliabilty........
.....Then I reached out and thought I'd try for the 100th time, the R65 forum, expecting it to time out again.....and it worked.
Hoping the collective knowledge in here might see me through.
Re: sign from above????
« Reply #1 on: October 30, 2007, 05:20:34 PM »
It's good to hear from you again, the last time I can remember a post form you, was after your trip to the US and Mexico, seems like about 5-6 month's ago.
Kind of makes you wonder about a member that all of a sudden stops posting, and you don't hear from them again !
I have not had a problem with this site, but quite often the Boxerworks site comes up as filtered due to 'tasteless content' at work .
« Reply #2 on: October 30, 2007, 08:41:50 PM »
Hmmm...  ::)
milkman
« Reply #3 on: October 30, 2007, 11:07:24 PM »
I think you're right Bob
That was in Feb? Then I was in the UAE for a stint. Seems like a lot longer.
I think all you Northies were just dusting off bikes for riding season, and now you're probably all putting them away again?
« Last Edit: October 31, 2007, 12:21:44 AM by milkman »
« Reply #4 on: October 31, 2007, 10:30:54 AM »
Milkman
I have not put the bikes up for the winter season , since I moved to Phoenix 14 years ago today, but the riding season is coming to a close in the northern parts of the US and Canada.
Rob Valdez, the comment was just a generalization, as since the beginning of the year, there have been 7 employees of Southwest Airlines that have lost their lives in motorcycle collisions.
So it just makes me a little more concerned, about someone that 'falls of the face of the earth'.
Four have been in the aircraft maintenance department, so I get a little more info on the incident, than if it was somebody in another department.
Five of the seven were involved in  incidents, where an on-coming vehicle made a left turn in front of them at a major intersection.
One involved my immediate supervisor back in May.
The last one was an employee from Jacksonville, Fl. hit a deer somewhere in West Virginia, and went off the road and down a ravine. It was two weeks after the incident, before he was found.
« Reply #5 on: November 04, 2007, 01:17:00 PM »
Hi Milkman,
Glad you got back.  We do wonder what happens to people.
So I thought I'd take this opportunity to say that I haven't disappeared.  Life has just gotten way too busy.   [smiley=2vrolijk_08.gif]  I'll be back to posting soon.  I've got some electrical stuff going on - battery not charging.   And I haven't had time to work on it yet.   :'(
« Reply #6 on: November 04, 2007, 02:00:11 PM »
HI MILKMAN AND MELENA!!
Glad to have you back.   I know what you mean about life getting too busy.  I've been a little slack in reading this board lately as well.
« Reply #7 on: November 04, 2007, 02:23:33 PM »
Hi Melena!! So good to hear from you and Aïda too. I haven't been on too much this summer either. Great to hear from Milkman and I just wish I could help him fix his gremlins described in the maintenance/work section
Love Aïda's emoticons....you are good at finding these!
« Reply #8 on: November 04, 2007, 03:01:05 PM »
Hi Milkman, Aïda, Sue, Melana, Rob and Bob,
Nope.  Still here lurking and putting my two cents in here and there.  I'll be riding here in Atlanta all winter - Gerbings at the ready!  I just did a the winter service on the R65LT and I have a new leak!  Both the gear shifter and the neutral switch are leaking (again).  So I need to do the spline lube and I will get both of these them some after the middle of November.  Contemplating trips about the country next year.  I have a class re-union in June in Mass and a fishing trip in Oregon in July - can you say "road trips".
I knew you could!
Don't give up on the electrical.  Check for good grounds and also open green and black power wires underneath the speedo tach that are for optional equipment.  If the ignition is cutting out then look at the coils and the mounts.  They can be troublesome.  As long as you come back we will be here.
Sincerely,
milkman
« Reply #9 on: November 06, 2007, 12:20:00 AM »
Well, its not electrical......I've tested everything, including my mechanic being nice enough to lend me his test unit parts and let me test them myself for free.
Playing with carbs now, and the screws on the top have decided to go soft and strip, even when always using the correct size driver and being careful.
It continues. If teh carbies don't sort this out, I'll try a match in the fuel tank.
No, I can't be too harsh, Betsy just took me 2400km with no dramas, and is still going, just not very well.
I won't be putting the old mule down yet. Have to keep the LS on the road
« Reply #10 on: November 06, 2007, 06:28:36 AM »
Usually a hand impact driver is required to get these screws out.  I replace them with stainless steel allen head screws...
« Reply #11 on: November 06, 2007, 07:42:57 AM »
If the phillips head is not completely buggered up, try some valve grinding compound on your screwdriver bit.
Other wise you're  going to have to drill them out.
 If do get the screws out, use some anti-seize compound on the threads.
Might not be a bad idea to use anti-seize compound on fasteners as you work on your bike.
As I remember, that you reside in on a salt water coastal area .
That 'salt air' is pretty tough on aluminum.
« Reply #12 on: November 06, 2007, 10:10:59 AM »
Bill G. Good to hear from you too!    Can you say BMW MOA International Rally in Gillette, WY.???? Sorta enroute to Oregon in July. :o And, the Top of the Rockies rally at Paonia CO. is the next weekend. I'll have to check out which weekends exactly for you.  Be back!
milkman
« Reply #13 on: November 07, 2007, 12:02:10 AM »
Yep, I'm drilling those little suckers.
BAck ones on both sides were fine, front ones on both carb lids were drill out jobs
Interesting as I'd taken them both off before, no drama.
I'm not on the water, but close enough....damn salt.
« Reply #14 on: November 07, 2007, 06:50:00 PM »
Use the stainless screws as replacements.  You can get a kit from Bing that has 4 screws, some anti-seize, and an allen wrench for about $8.  Or, I sometimes sell just the screws on e-Bay, let me know if you want some...
