Author Topic: I need a petcock plug...  (Read 2518 times)
Bonneybear
« on: June 10, 2008, 06:43:47 AM »
Im putting a R100 tank on my bike, It has 2 outlets. I would like to run only one pet cock though. where can i get a cap/plug for the right side?
airhead
Re: I need a petcock plug...
« Reply #1 on: June 10, 2008, 07:14:39 AM »
Maybe get the screwed nut from a junked petcock and put a blank (coin??) of suitable size with some sealant to block the opening.
However, why not take advantage of the twin petcocks, like two reserves, extra flow, redundancy etc.
Bill........................;-)
Jon_P
« Reply #2 on: June 10, 2008, 08:37:41 AM »
some of the harley petcocks fit in there, think it was the pre FI models. Drag Spec. also has a block off cap for them.
« Reply #3 on: June 10, 2008, 08:02:09 PM »
I also vote for using both petcocks.  Remember, there is over a pint of gas that you can't use unless you tip the bike over with a single petcock.  Post pics of the conversion when you're done as I have thought about doing this as well...
