Author Topic: Steering bearings  (Read 818 times)
Danno
Steering bearings
« on: May 28, 2008, 08:04:50 AM »
The steering on the R65 is or has gotten really tight. Is there anything unusual I need to be aware of as I disassemble to check it out? What has me concerned is that I noticed what look like pipe wrench marks on the big knurled nut.
Re: Steering bearings
« Reply #1 on: May 28, 2008, 10:51:41 AM »
This thread (click on link below) should give you plenty of relevant info, and even some pointers & pictures:
http://suraklyn.com/yabb/YaBB.pl?num=1175535024/0
Danie
« Reply #2 on: May 28, 2008, 10:58:59 AM »
Hi Danno
I am not a technical expert, but maybe it is about time to replace the stearing bearings. I recently experienced the same problem with my Kawasaki, and during inspection I discovered that the bottom bearing was badly rusted, and had to be replaced.
I do have a feeling that this could be a common problem with many of the older  bikes -regardless make or model.
Regards
Danie
« Reply #3 on: May 29, 2008, 07:32:25 PM »
Danno,
Also have a look at the excellent post by SueCanada that I stole and posted in our Tech section
http://suraklyn.com/yabb/YaBB.pl?num=1189357717
Danno
« Reply #4 on: May 30, 2008, 07:45:46 AM »
Thanks.
Great write up.
Dan
