Author Topic: Hello from South Africa  (Read 4353 times)
HOFFI
« on: February 15, 2015, 02:00:09 AM »
Hi there to all here, I have just bought an 1980 R65 which as expected needs some TLC.
I will post some pics as soon as i have some...
Re: Hello from South Africa
« Reply #1 on: February 15, 2015, 08:46:28 AM »
Welcome to our ever growing asylum. Lots of experienced inmates as yet unparoled so ask any questions you may have. If we don't know the answer, we're sure to make up something.
Yes, we love [smiley=camera_sm.jpg]
HOFFI
« Reply #2 on: February 16, 2015, 09:59:38 AM »
thanks for the welcome and offer on the brain picking. as promised. i have all the missing bits in a box.
Offline ShutterPilot
« Reply #3 on: February 17, 2015, 03:39:50 PM »
Hello, and welcome!
I think Montmil has a "dashboard" for sale, if you're looking to replace your missing one... ;)
HOFFI
« Reply #4 on: February 17, 2015, 10:44:29 PM »
Thank you. I have got the dashboard I'm busy replacing the cables so I removed it...hopefully I get them back today. Then it's a carb refurb and a tank clean and seal then the hard work starts...
Offline Jock
« Reply #5 on: March 03, 2015, 12:37:10 AM »
Howzit Hoffi
Another South African member (Durban). I have a 1984 R65 and am as happy as a pig in s..... with it. I have had a few BM's. R100RS which I found too heavy and an old 1962 R50 which I had for 42 years. The R65 is the best of both worlds - enough power and lightweight - I love it.
Jock
« Reply #6 on: March 03, 2015, 07:15:26 PM »
Welcome aboard!
Yes, you do have some project time there - but you can do it with patience and persistence !
We are here to help!
« Reply #7 on: March 06, 2015, 01:00:14 PM »
I may I just say that when it comes to help here in this forum, it is the best!! Never ever feel that your question or problem is not worthy. This is a very polite forum!
HOFFI
« Reply #8 on: June 30, 2015, 03:48:09 PM »
Just for a little update on my small rebuild. All cables have been replaced. Carbs have been stripped cleaned and are just awaiting new main jets. All the lights and housings have been cleaned and blackened. Dash repaired and again blacked. The tank is in for a cleaning and petcock has been stripped and cleaned and is ready for use.
Next on the list.
Exhausts unfortunately  I can't find original exhausts for anywhere near a reasonable price I have found guys that have Pretty good looking replacements
Brakes redoing all the brake lines.
Front shock service
And then at least I should have a running bike again.
Slow
« Reply #9 on: July 01, 2015, 08:10:18 AM »
Hi Hoffi, welcome to the forum.
Nice to see another SA member. (I am based in Bloemfontein)
Enjoy your project.
I found local BMW dealers very helpful and reasonably priced on all spares in SA. Getting spares from over the water just becoming to expensive with our Rand losing value against the $ & £.
HOFFI
« Reply #10 on: July 02, 2015, 07:33:56 AM »
That is for sure. I have started dealing with a company in the south of joburg. Cytech they were very helpful and prices don't seem ridiculous.
Slow
« Reply #11 on: July 03, 2015, 12:07:45 PM »
Yes I have used Cytech a few times, good service.
HOFFI
« Reply #12 on: January 20, 2016, 12:51:41 PM »
Ok so its been a while.
again another update and a few questions.
my bike is running probably not as well as it should be but at least i can climb on start it and do a few kays.
this is where the questions come from.
1. My rear end keeps seizing up (swing arm gets stuck in lowest position and the shocks are at max compression) has anybody had this before? i will have to look at doing the swing arm bearings anyway.
is there a local south african supplier i can get them from? are they standard taper bearings or BMW specific?
2. Also a local south african supplier for the rear shocks yes  would need 2?
3. and to break away from the std original rebuild i have heard of a two into one exhaust system that is makes a very attractive sound, are there any views on this type of exhaust.
« Reply #13 on: January 20, 2016, 01:46:33 PM »
I hate it when my rear end seizes up. Usually from eating too much cheese.
As to your R65, two things come to mind: 1) Rear shocks are frozen. No oil in them but lots of rust jamming them and, 2) Swing arm bearings in bad shape. Perhaps rusted and binding for lack of proper maintenance.
The swing arm bearings are a common size available at most any bearing supply house. Size is stamped on the race. You may find both sealed and non-sealed bearings. Go with the unsealed and re-grease them yourself prior to install.
You'll notice a hole in the swing arm "pin". After the new bearings are in, use a conical-shaped rubber tip on a common grease gun and pump grease into the swing arm until it begins to ooze out. It may take quite a bit of grease but it will prevent water / condensate from fouling the bearings.
You will need to modify a 27mm socket to remove and replace the pivot pins. By using a belt sander, remove the rounded or beveled face of the socket. Note the hex on the pivot pin is quite thin and a conventional socket will not have enough purchase.
Have you a Clymer or Haynes shop manual? having both is helpful. Where one manual glosses over a procedure, the other may go into more detail.
When you get it sorted, let us know what you find.
HOFFI
« Reply #14 on: March 29, 2016, 02:44:44 PM »
just a short update and again a few questions.
after the last time i had posted about the sticky rear end. i have taken it upon myself to replace all my bearings. Starting with the steering head bearings (while i had the front end apart refurbishing the front shocks) so the hard part is done....old bearings removed new bearings bought.
Question 1: what type of grease needs to be used? if it helps at all as mentioned before i do live in south Africa on what we call the highveld so moderate temperatures all year round and very low humidity.
then to put the new bearings in:
my plans
for the lower bearing heat up the inner part of the bearing via the oven cool the lower yoke via the freezer. then a hope and prayer an a push the bearing on the shaft.
for the upper bearing
cooling of the race and the same hope and prayer
upper inner race heating praying and pushing pulling
ok so my plan is pretty vague. but its the general idea.
any other advice is always welcome.
