Author Topic: fork braces - rain grooves  (Read 1166 times)
Offline Oconner
  • Sunny So Cal.
« on: August 20, 2015, 03:10:49 PM »
I was reading an old moto mag and there was and advert for fork braces and one of the claims was that it eliminated the wobbles I get on the wonderful CA rain grooved freeway above 70mph. I have Avon roadriders by the way. Anyone have any thoughts? You cant escape the freeways here in So Cal!
'82 r65LS
'72 Honda CL 350
'13 FZ6R
Re: fork braces - rain grooves
« Reply #1 on: August 20, 2015, 05:17:31 PM »
You already have a fork brace on your R65, unless a PO errored and removed it. It's that heavy steel part under the front fender.
As far as rain groove induced wobbles, some tires do and some don't. I have Bridgestones Spitfire S-11 on both R65s and my R100S. The few times I've ridden on grooved pavement, there has been no noticable twitching.
Are your steering stem bearings greased and properly adjusted with just a smidge of pre-load? The swingarm has the same bearings and they also require a little preload. Either or could induce the wobbles.
« Last Edit: August 20, 2015, 05:21:32 PM by montmil »
Offline Oconner
  • Sunny So Cal.
« Reply #2 on: August 21, 2015, 10:26:27 AM »
Yep fork brace is there. Live and learn. Will check the bearings.
Thanks
'82 r65LS
'72 Honda CL 350
'13 FZ6R
« Reply #3 on: August 21, 2015, 01:31:28 PM »
Have you tried different tire pressures to see if that would make a difference ?
« Reply #4 on: August 22, 2015, 08:05:59 PM »
A few PSI in the tires does indeed make a difference, along with the tire design.   We don't have rain grooves here in the Northeast - but we do have scarified pavement in the summer with road resurfacing - think mega-rain grooves- which no tires is immune to but some are much much worse than others.  We also have metal grate deck bridges that get both slippery and groovy when wet.
I used to ride on the Metzler lasers with the block type tread patterns back int he 90s - but they were awful on those surfaces.
I am presently riding Bridgestone BT45 tires on the R65 and they work great.   However, I have found that if I forget to check tire pressures and the front tire gets down to ~24-26PSI, I will have an unpleasant wobble right between 40-45 MPH.
