Author Topic: New member  (Read 4459 times)
Offline jamestnewsonr65
New member
« on: April 17, 2014, 05:23:21 PM »
Hi, glad I found you guys.
A quick hello from a new member and new to bike owner.
I have my first which is a 83 r65ls, but I'm in the process of strip down for powder coat and paint etc. Engine will stay as is for the time being with only cosmetic changes. Was all running fine before tear down so just a clean and reassembly.
Hoping to get some good help when needed and probably ask the odd newbie question!
As you can see in the pics, I have gone to work already!
« Last Edit: April 17, 2014, 05:24:43 PM by jamestnewsonr65 »
1981 R65 (box of bits).
Re: New member
« Reply #1 on: April 17, 2014, 08:04:04 PM »
Welcome aboard, James.
Your '83 LS has some features found on earlier Mks such as the ATE brake calipers from the 79-80 era and the earlier design "hernia" centerstand. Dome-top Bings and the newer style air box say 1981> plus the wheels are LS-specific.
Your last seven digits of the VIN, plus this site, will get you your bikes month and year 'born on' date.
http://www.realoem.com/bmw/select.do?vin=6387284&part=&kind=P&arch=0
Keep us posted.
Re: New member
« Reply #2 on: April 18, 2014, 01:49:19 PM »
I did wonder why the calipers weren't brembo. Looking at real oem it says the bike was registered in 12/81 but it was registered in the uk in 83. It had all the fairing on it when I bought it but will be selling all the bits I don't want.
I will be going for this look...... And probably posting silly questions!
Re: New member
« Reply #3 on: April 18, 2014, 03:44:28 PM »
Most likely BMW Motorrad was using up leftover bits from the 1979-80 bikes before all the newest '81 parts hit the assembly line. Common practice at the Mothership.
Some of the lads in the UK and a few here in the Colonies have made up "wooden planks" covered with vinyl as is most likely the one in your photo. Should you go that seat route, keep a tube of 'Preparation H' in the under-seat tray. Your 'roids are gonna need it.
BenjisMoto
Re: New member
« Reply #4 on: April 19, 2014, 02:32:49 AM »
Looks like a good looking bike! Cant wait to see how it turns out.
p.s. always listen to Monte, he's what you call an expert ;D
Re: New member
« Reply #5 on: April 19, 2014, 08:03:05 AM »
... p.s. always listen to Monte, he's what you call an expert ;D
That's a load. I've just made more errors than most so you can chill on the expertin tag.  ;)
Re: New member
« Reply #6 on: April 19, 2014, 09:47:03 AM »
But if Monte wagers a beer on something, don't bet against him  ;)
btw, James, my '82 LS sports the same calipers and center stand.  Looks like your "target bike" has moved the battery to underneath the transmission.  Never seen that before.  Looks pretty sweet!
BenjisMoto
Re: New member
« Reply #7 on: April 19, 2014, 11:08:25 AM »
My 81 r65 has the dual discs as well.
That's most likely what I am going to do as well, boxer metal sells one for $150, not sure if it fits the r65, I'm just having my local fab shop fix one up for me to save $$  ;D
Re: New member
« Reply #8 on: April 20, 2014, 02:18:18 AM »
For this one I think I will try and keep a lot of it stock and then be a bit more adventurous with the placement of parts once I actually know what I'm doing!
Steep learning curve, but enjoying at the moment and that's what counts.
I'll happily take advice from an 'expert' even if he doesn't want to be called one.  :)
Re: New member
« Reply #9 on: April 20, 2014, 12:02:54 PM »
I was going to move my battery under the transmission, classic BMW racer configuration. The only problem is you lose your centerstand, they won't both fit in the same space.
BenjisMoto
Re: New member
« Reply #10 on: April 20, 2014, 10:29:29 PM »
Im not so sure if that is true or not, im currently fabricating one for my bike with a very small 8cell battery I bought from Alien Motion. if all goes as planned i could be able to keep my center stand on! I will post pics when its done and if it works i can send you dimensions.  ;D
RSMike
Re: New member
« Reply #11 on: April 21, 2014, 12:43:36 AM »
Georg Bayer (http://www.bmwbayer.de/) is a great source for new parts. Good luck, looks like you have a great base.
DerekM
Re: New member
« Reply #12 on: April 21, 2014, 02:35:08 PM »
the bike looks good, you could also consider moving the battery up under the seat too. keep the pics coming.
Re: New member
« Reply #13 on: April 22, 2014, 04:01:45 PM »
@rsmike thanks for the link, that's one I've not found as yet. Used motobins and motorworks so far.
Will start a resto thread when I get some time. Having the bearings pressed out the hubs and races out the steering head on Thursday then all is dismantled, so will have a bit more time.
Re: New member
« Reply #14 on: April 22, 2014, 04:45:08 PM »
Just a heads up if you didn't already know... the LS wheels require heating the hub before you remove the bearings to avoid (potentially) destroying the expensive and hard to come by wheels.
