Author Topic: voltage problem  (Read 1097 times)
fastcataz
voltage problem
« on: May 11, 2008, 12:46:07 PM »
My stop light....stopped, working that is. I changed the bulb, no joy. Pulling out my trusty meter tells me that I am getting 12V at the rear light, but only 8V at the stop bulb. Any ideas?
Re: voltage problem
« Reply #1 on: May 11, 2008, 12:54:41 PM »
Bettin' you have a partially broken/pinched/or old wire with way to much resistance. Get your multimeter out and start tracking the wires from the bulb to the brake switch. Hold on... could be the brake light switch itownself.
Resistance is futile be it the Borg or 24 year old wiring. I'd be looking at the switch first. Ground wires are often culprits, too. They be brown - mostly - on things German.  Good luck!
« Last Edit: May 11, 2008, 12:55:51 PM by montmil »
Re: voltage problem
« Reply #2 on: May 11, 2008, 01:39:10 PM »
Time to start looking for corroded connections in the wiring harness.
Possible that a switch is giving you problems.
Does the same thing happen, whether you use the front or rear brake switch ?
« Last Edit: May 11, 2008, 01:40:38 PM by Bob_Roller »
fastcataz
Re: voltage problem
« Reply #3 on: May 11, 2008, 02:47:04 PM »
Hah. Front switch is broken. Cleaned and checked connectors, still 8V. Got bored and ran a single wire around the harness, now we got stop. Light that is..
Re: voltage problem
« Reply #4 on: May 12, 2008, 06:06:47 PM »
To quote the great Hannibal, Smith, not Lector, "I love it when a plan comes together." Light 'em up!  [smiley=beerchug.gif]
