Author Topic: Brembo Brakes  (Read 1056 times)
Brembo Brakes
« on: March 20, 2013, 02:14:46 PM »
Willie the "K" is well on the mend after our little spill and a lot of help from ebay, i got all the parts for less than £100 ( fairing, wheel and disc) and while the front wheel is in bits i decided to strip the front calipers to double check possible causes for the "lumpy" braking  as i am replacing the alloy wheel and one of the disc rotors with a new to me one and dont want to damage the replacement by missing something dumb.
 I wanted to check the pistons were all free and was surprised to find they are made of a hard plastic or ceramic, i just wondered when these were introduced Willie is a 93.
« Last Edit: March 20, 2013, 02:16:26 PM by Lucky_Lou »
Re: Brembo Brakes
« Reply #1 on: March 20, 2013, 02:17:53 PM »
Interesting, at least they won't corrode .
Re: Brembo Brakes
« Reply #2 on: March 20, 2013, 02:47:10 PM »
They are not the same as the replacement pistons offered by Motworks as these have a small flange/ tang on the inside Motobins dont show the back but the material looks the same ??.
Offline Julio A.
Re: Brembo Brakes
« Reply #3 on: March 23, 2013, 09:13:20 PM »
I disassembled brembo calipers both from a R100, an R65 and from a K100. The one from the R65 and the K100 has this flange you were talking about but the one from the R100 has no flange and is flat all the way. Since the piston from the R65 caliper was slightly damaged, I'm using the piston fom the R100 with no noticable difference in performance. The caliper from the R100 was from the earlier models with the rear disc brake though.
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
