Author Topic: Goodday to you all from a new member  (Read 3284 times)
Offline Graeme
Re: Goodday to you all from a new member
« Reply #15 on: April 30, 2012, 07:12:46 AM »
Thanks Barry. It says "up to 4/82?"
1985 R65 LS
Offline Matt Chapter
  • <insert witty remark here>
« Reply #16 on: April 30, 2012, 10:34:21 AM »
Usually indicates month and year the part fits, in this case, no bikes manufactured later than April 1982.
IANAL, consult your doctor before using this advice, do not operate heavy machinery under this influence, etc.
'04 R1150 RT ~41000 miles
Offline Graeme
« Reply #17 on: May 01, 2012, 12:25:07 AM »
Usually indicates month and year the part fits, in this case, no bikes manufactured later than April 1982..
Sure, Matt, but I can't find anything that indicates a change in the gearb ox specs or ratio's throughout the model.
1985 R65 LS
« Reply #18 on: May 01, 2012, 08:45:33 AM »
Sure, Matt, but I can't find anything that indicates a change in the gearbox specs or ratio's throughout the model.
The change was in the angle of the helical gears. Forget the actual angle but early and late versions are definitely not compatible. You can buy this special 5th gear pinion in both versions though on the same website.
« Last Edit: May 01, 2012, 08:47:17 AM by bhodgson »
Offline Graeme
« Reply #19 on: May 01, 2012, 06:07:02 PM »
Aha! Thanks guys!
1985 R65 LS
