Author Topic: Wheel Rim concern  (Read 1700 times)
Rubi76
Wheel Rim concern
« on: January 21, 2012, 02:03:45 PM »
Hi Guys,
Is this normal ?
I have never seen this before on a rim. it looks like its a 2 part rim.
Offline donbmw
Re: Wheel Rim concern
« Reply #1 on: January 21, 2012, 02:22:09 PM »
I will go look at mine later. But it looks like casting lines to me.
Don
« Reply #2 on: January 21, 2012, 02:22:38 PM »
It's pretty much common on the LS wheels .
The wheels are a two part casting .
Up to now, I have never heard of this getting any worse, or having the wheel separate .
Rubi76
« Reply #3 on: January 21, 2012, 02:38:57 PM »
Thanks for the fast feed back,
That puts my mind at rest, Will get them resprayed a little later on this year. just have to do some good prep work on it.
« Reply #4 on: January 21, 2012, 07:50:23 PM »
Yes, if those are LS wheels, they all do that.  It is cosmetic only.   BMW made these wheels with a very hard material rim, and a different spoke material that was designed to have a slight degree of flexs, to mimic the behavior of spoked wheels.   The line is where the 2 parts have been pressed together - the paint may crack there but it has no safety issue - everyone who has an LS experiences this until they repaint their wheels.  Some paint is better at handling this application that others, cracks may re-appear or not within a year of repainting.
« Reply #5 on: January 21, 2012, 08:15:31 PM »
BMW had a service bulletin about this right after the LS's got out on the street .
Their 'fix' was to put white or grey tape on the crack area, depending on the wheel color .
The tape is no longer available .
My '82 LS has had the wheels powder coated, it cracked through that in a short time, so if you decide on something, the material needs to  be 'flexible' .
« Last Edit: January 21, 2012, 08:16:12 PM by Bob_Roller »
« Reply #6 on: January 21, 2012, 09:33:33 PM »
... My '82 LS has had the wheels powder coated, it cracked through that in a short time, so if you decide on something, the material needs to be 'flexible'.
Check with your local autobody supplier regarding flex agents that can be added to paint.
