Author Topic: Oil Head Owners  (Read 1566 times)
Oil Head Owners
« on: October 17, 2011, 03:24:43 PM »
I have heard over the past few years about problems with the wiring harness where it is secured to the steering head area .
More precisely, the harness is too tight, causing wires to break .
Well, I've developed an intermittent instrument internal lighting problem .
If I flex the harness at the steering head, I can duplicate it .
Now I need to find out which wire it is, as none of the wires are chaffed or physically broken .
So you oil head owners out there might want to look at this before any problems develop for you !!!!!
Re: Oil Head Owners
« Reply #1 on: October 17, 2011, 10:03:31 PM »
Oh, nice...  Is the issue being "tied" to the frame too tightly or not enough slack where stuff rotates?
Re: Oil Head Owners
« Reply #2 on: October 18, 2011, 09:40:20 AM »
It appears to be to tightly secured, the wiring sheath, like thin rubber hose over the wires is coming apart in this area .
Re: Oil Head Owners
« Reply #3 on: October 19, 2011, 08:38:46 PM »
Generally my electrical problems tend to be permanent and defy diagnosis.  To wit, the clock on my R1100S has never worked.  I've done trouble shooting a couple of times but unless I want to completely unwrap the entire steering hear harness I'll never know.  Oh well, it's just a clock.
Re: Oil Head Owners
« Reply #4 on: October 19, 2011, 08:53:25 PM »
Have you checked your fuses, should be a 7 amp brown fuse that powers the clock .
The clock is on the same circuit as the electrical accessory outlet .
I've melted a few fuses from disconnecting the electrical connector when I had the float charger on it .
Don't quite know what I do wrong on occasion when I pull the plug out, but it happens on occasion .
« Last Edit: October 19, 2011, 09:35:50 PM by Bob_Roller »
Offline DeeG
Re: Oil Head Owners
« Reply #5 on: October 20, 2011, 11:35:23 AM »
Never had a problem on my 97 R850.  But its something to keep in mind when I start the tear down to replace the fork seals.
Dee G
1978 R45/N ?
1978 R80 w/hack
1971 R75 (swb)
Re: Oil Head Owners
« Reply #6 on: October 20, 2011, 01:27:00 PM »
This may be just a problem with later year  bikes .
Re: Oil Head Owners
« Reply #7 on: October 21, 2011, 12:56:53 PM »
Bob, at a tech day last year I completely removed the plastic and ran as thorough an electrical test as I could.  All fuses are good.  I did determine that there is probably a break in the wiring between the clock and the harness but that bundle is so big I decided it just wasn't worth it.  And like I implied before, why worry about what time it is when you're riding?  I do kind of wish I could find a good way to mount a gps on that bike but there is no good way to do it.  Besides, there are no wrong turns on a motorcycle. 8-)
Re: Oil Head Owners
« Reply #8 on: November 02, 2011, 08:38:44 PM »
The lights finally quit working last night .
I had the bike apart, with the fuel tank off for a battery change .
Cut all of the ty-wraps off of the wirng harness and opened up what little bit of rubber hose over the wiring was left .
Quickly found the broken wire, two minute repair .
Now I need to find some flexible 'conduit' to put over the wiring bundles .
