Author Topic: Thinking time.  (Read 1867 times)
Offline BooG
Thinking time.
« on: May 21, 2010, 01:03:33 PM »
I've been riding a K75 around recently, and I like it, but the R65 has a lot of class that you just can't match.
So, my cylinders fire with a bit of carb cleaner in them, but then cut out again. So there is a fuel issue thru the carbs somewhere. The plan? Buy some 32mm Bings off ebay to test with, and if I get a result ,keep em. R65 hasn't run since November!!
BMW R65 1980.
Vespa Sprint Veloce 1971
BMW K75S 1987
Re: Thinking time.
« Reply #1 on: May 21, 2010, 02:48:43 PM »
Just be aware that there are a lot of different Bing carbs in the 64/32 series .
There's a set of numbers stamped into the vertical flange at the front of the carb, should be something like : 64/32/325 .
Try to get a match if you can .
Any chance of a shop in your area that may have Bing carb repair knowledge ?
Re: Thinking time.
« Reply #2 on: May 21, 2010, 08:02:04 PM »
Hey just clean the ones you have.  They are not that complicated!
« Last Edit: May 21, 2010, 08:02:19 PM by Semper_Gumby »
Offline BooG
Re: Thinking time.
« Reply #3 on: May 23, 2010, 04:22:33 PM »
Have cleaned them, re-built them and they still are problematic I think. The coils deliver a good spark. Compression seems ok....Maybe a good quality ultra sonic clean?........ :-?
BMW R65 1980.
BMW K75S 1987
Re: Thinking time.
« Reply #4 on: May 24, 2010, 01:00:18 PM »
Given all you've been through I think that's not a bad plan.
Carbs are saleable items so you can always sell a set once the problem is resolved.
Pity there is no one with an airhead nearby that could lend you a set just to get that engine started.
Re: Thinking time.
« Reply #5 on: May 24, 2010, 01:09:07 PM »
I'm at a loss of where to go from here, as I remember, your problem came on suddenly after the bike got rained on heavily while you were at work .
I know my bike will start at least and run poorly, if one carb isn't working .
I just can't figure out why both carbs would be at fault !!!!
I hope you can actually find out what the problem is .
Re: Thinking time.
« Reply #6 on: May 24, 2010, 01:41:00 PM »
Just a thought....post the carbs to me ill test them on mine for you pm me if you want to do it.That said my carbs were troublesome untill i had them U/S cleaned cost  30 quid but worth evey penny.
Re: Thinking time.
« Reply #7 on: May 24, 2010, 07:22:38 PM »
Did you check the jet in the bottom corner of the float bowl.  Many people clean the carb bodies but miss this important jet.  If its clogged....
Good luck!
Offline BooG
Re: Thinking time.
« Reply #8 on: May 25, 2010, 04:18:36 PM »
Yeah..even the jet in the bottom corners!! Replaced every seal etc!!
Maybe its not the carbs....however, that's a great offer Lou, and if you had the time and energy, I would be more than willing to post em north!! Got a baby due Thurs, so won't be up to much fettling for a week(s) or 18 years!!! ;D
BMW R65 1980.
BMW K75S 1987
Re: Thinking time.
« Reply #9 on: May 26, 2010, 09:31:49 AM »
18?.......25 or more if they go into further education....
I have a 14 year old and 9 year old.....not even half way through...
Ho hum!
Steve Hawkins
