Author Topic: A new memeber from Japan  (Read 4405 times)
Re: A new memeber from Japan
« Reply #15 on: March 23, 2010, 08:52:38 PM »
Also, other than the paint, there is nothing unique about the LS tank from the rest of the twin-shock R65s, so any R65 tank would work for you.
yf6354084-1983
« Reply #16 on: March 23, 2010, 10:24:44 PM »
Thanks for kind advices, and POR15 tank sealer will be applied which is available and ready here. The matter is rust removing, because they are located right side bottom; can be checked only by small mirror...not enough, can't touch, supposingly the rust is no more because other surface has changed to steel itself. It's something GAMBLE. Good luck for enjoying difficulty. YF
« Reply #17 on: March 23, 2010, 11:41:23 PM »
You need to find a small light-camera that you could use to see inside.  (good luck!)
http://www.fiberscope.net/servlet/the-Videoscopes/Categories
By the way, your English is very good.  Much better than my Japanese! (none)
« Last Edit: March 23, 2010, 11:54:36 PM by Rob_Valdez_79_R65 »
