Author Topic: Winter blah's  (Read 1031 times)
stockman
Winter blah's
« on: February 07, 2010, 08:02:00 AM »
I have cabin fever. Its 16 degrees and windy outside today so there is no chance I would take the R65 for a ride today but I  would love too.
I just had to tell someone thanks for listening. :(
Re: Winter blah's
« Reply #1 on: February 07, 2010, 08:10:05 AM »
It was raining quite heavily when I left for work this morning at 0515, so no motorcycle today .
I brought the fuel tank from the LS into work, hopefully, the phosphoric acid will remove the flash rusting, and not rust up again when rinsed with hot water, so I can finally get the liner back into the tank .
Re: Winter blah's
« Reply #2 on: February 07, 2010, 08:17:00 AM »
Bob, are you using the POR 15 kit?  If not what procedure to reline the tank?
Re: Winter blah's
« Reply #3 on: February 07, 2010, 09:17:34 AM »
I'm using the POR 15 kit, but my use of citric acid, caused flash rusting when the tank was rinsed out with hot water .
I finally have some free time, so I can continue the work on the LS .
Haven't had enough time over the last 2 month's to devote a whole day to this, hopefully, this will be the final work on the tank interior .
