Author Topic: I'm doing better!  (Read 1929 times)
I'm doing better!
« on: May 27, 2009, 12:49:35 AM »
The physical therapy seems to be really taking off, as of late.
I don't know if it is the pull of the warm weather, here in the Northern Hemisphere, or if it is the inspiration of a [long-distance] love interest (;)).
Probably a little of both.
Regardless, this is the result I achieved here at work tonight!  Normally I can only bend this far after a session with the therapist.
I haven't seen her since last Wed.!  :D
Thumbs up, indeed!
As for the bike, I have most all of the bits on hand to get it back together.  I just placed an order with Matt @ Boxerworks today for even more stuff.  But this last weekend was a good one.
I have been stripping bits off of the engine for a couple of weeks, now, but Sunday I removed the last - the starter motor and the clutch and flywheel (I pulled the flywheel without blocking the crankshaft!!! lol!).
I had removed the heads and cylinders a while back, as one of our posters was anxious to buy the cylinders from me.  So Monday I removed all 8 cylinder studs and drained the oil.  This was as light as the case was going to get, at this point.  I surprised myself by getting it out quite easily!
I then spent a couple of hours wiping dirt and grease off of the frame, and then I called my nephew over to help me lift the new engine in place.  I have my work bench back, again!!  (the engine had been sitting there since November... :'()
And that is where it stands, for now.  I need to get some different size fasteners for removing the late-model clutch assy.  I'm planning on replacing the rear main seal while I am in there.
I also hope to do a complete tear-down of the front-end.  The forks have needed cleaning out for a while now.  I was planning that even before the crash.  I also want to renew the bearings at both the steering head and the swing arm.
I just hope my fork tubes roll "flat" on a sheet of glass.
Well, only 4 characters remain.  All for now!  :)
« Last Edit: May 27, 2009, 12:50:16 AM by Rob_Valdez_79_R65 »
Re: I'm doing better!
« Reply #1 on: May 27, 2009, 02:21:40 AM »
Great to hear of your good progress.
At this rate you will be back on the road before the summer has really got going.
Don't take your foot off the gas!
Steve H
aussie
« Reply #2 on: May 27, 2009, 03:39:23 AM »
Way to go Rob - on all counts (the hand; bike and the love interest)!
Keep it up.  [smiley=thumbsup.gif]
« Reply #3 on: May 27, 2009, 09:38:43 AM »
...Keep it up.  [smiley=thumbsup.gif]
Aussie, You funny guy!  ;)
« Reply #4 on: May 27, 2009, 09:39:33 AM »
« Reply #5 on: May 27, 2009, 10:39:44 AM »
Outstanding, Rob!!!
Very happy to hear of your progress.  Keep pursuing all three of your therapies.
Ed
« Reply #6 on: May 27, 2009, 11:29:48 AM »
Glad you're recovering use of your digits and getting to work on the bike,  Wrenchin's good therapy, almost as good as booze...
« Reply #7 on: May 27, 2009, 03:43:15 PM »
I hope that your physical therapist takes the news of your long distance relationship well and doesn't plan any 'scorned therapist' sessions with you and a couple of Greco-Roman Wrestlers!
Go Rob, go !!
« Reply #8 on: May 27, 2009, 09:54:49 PM »
The position of your digits shows improvement. Grease under your finger nails will show recovery! Keep at it, glad your back in form!
