Author Topic: I´m still alive  (Read 11817 times)
Re: I´m still alive
« Reply #30 on: March 18, 2009, 10:24:49 PM »
 ;D  Thanks Aïda!  I just liked seeing his eyes go around in circles when I thwapped him "upside his pointy head".  But those other 2 work also.  Hee hee!    Oh, my!  I do think winter is getting to me.  It's time to be getting outside more.
Dirk,  I sure hope I never find a valve like that in my bike.  Yikes!   :o  Those pictures are great.  I know we will all love seeing the magic you work on this bike.  Thank goodness you have a good place to work on it.
Re: I´m still alive
« Reply #31 on: March 19, 2009, 10:36:25 AM »
<snip>
I´ve continued my works on the R100. I found out that the compression on the left cylinder was about 11 bar and on the right only 2 bar. Vesterday I removed the Cylinderhead and found this totally burned out ventile.<snip>
Holy Moly!  That valve looks like Civil War era.  I bet the valve seat is also "toast".  But no valve "recession".  I guess R100 valves are made of sterner stuff than the R65 valves.  So what brought this on?  Too lean?   :P
« Last Edit: March 19, 2009, 10:38:54 AM by Semper_Gumby »
trolle
Re: I´m still alive
« Reply #32 on: March 22, 2009, 04:21:46 PM »
Very beautiful bikes, indeed. I wonder how you get the aluminium so clean?
On the subject of pinstriping:
Beautiful work! I have had Japanese bikes that used the clear coat over tape pin striping, an economical method that gives a good result. I always get a kick out of bikes in the house for repairs. My wife not so much! >:(
I have had all the parts of my wh8la2 painted black with a white pinstripe. The pinstripe was done by painting the background white, then a tape pin stripe was applied and the whole was painted black. When the paint had dried the tape was removed and a clear coat applied. The result is a slightly recessed pinstripe which is quite satisfactory as you can see.
greetings from a windy and cold north
aussie
Re: I´m still alive
« Reply #33 on: March 23, 2009, 01:39:26 AM »
trolle - you're doing beautiful work there. It will undoubtedly be a testimony to your diligence and painstaking attention to detail when it is complete.  [smiley=thumbsup.gif]
trolle
Re: I´m still alive
« Reply #34 on: March 23, 2009, 02:43:37 PM »
Thank you - it is nice when people appreciate one's work. My best friend, and we've been best friends for 45 years, do not believe in my ability to put the bike together again, but then he is a boat builder and looks upon me as a hopeless theorist.
Recently I suggested that we restore a '69 Citroén DS 23 injection when we are pensioned off - that would be the ultimate test.
greetings from a sunny and cold north
« Last Edit: March 23, 2009, 02:48:14 PM by trolle »
Re: I´m still alive
« Reply #35 on: March 23, 2009, 06:48:14 PM »
Super photos, Trolle, and I applaud your excellent work! [smiley=thumbsup.gif]
Looks like you and Dirk are in the same "highly skilled" category of technical abilities!  If you weren't so far away, I'd consider retaining you to do some "improvements" on Britta!  ;)
Yikes
Re: I´m still alive
« Reply #36 on: March 23, 2009, 07:43:51 PM »
Hard to believe that's the same bike, Trolle.  Will she be the wh8la3?  Really beautiful.  I love pictures of bikes inside the house!
Altritter
Re: I´m still alive
« Reply #37 on: March 23, 2009, 08:46:27 PM »
<< I love pictures of bikes inside the house! >>
Do I dare show the pic to spouse? I feel fortunate to be permitted to have mine inside the garage!
Seriously, that's a beautiful job!
« Last Edit: March 23, 2009, 08:47:30 PM by Altritter »
Re: I´m still alive
« Reply #38 on: March 23, 2009, 08:51:29 PM »
Nice Trolle.  Looks like your going to totally "renew".  Cool.   8-)
Re: I´m still alive
« Reply #39 on: March 23, 2009, 11:03:16 PM »
Trolle,
That is beautiful work.  You've done a great job on her.  Transforms the wh8la2 completely.  But now how are you going to call her that when she's not white anymore?  Or will she always be the wh8la2 to you no matter what?   ;)
Good job Trolle!
aussie
Re: I´m still alive
« Reply #40 on: March 24, 2009, 03:46:52 AM »
Now that I would like to see - I do love the lights and the hydraulics. There's a real estate salesman up around here that has one - it looks like a sweet ride. Would you get the hardtop or convertable?
Having said that there is 2CV that a lady drives around here as well - black and yellow (ummmm  ::)). The colour I'd give a miss, but it's a very cool car.
« Last Edit: March 24, 2009, 03:48:22 AM by aussie »
Re: I´m still alive
« Reply #41 on: March 24, 2009, 11:21:38 AM »
Anyways, back to the valve.  What mileage is on the R100?
ScottColumbus
Re: I´m still alive
« Reply #42 on: March 24, 2009, 05:06:21 PM »
@trolle: Very nice bike! You are a lucky guy because you have a warm and clean workshop!
I envy about you.
@Steve Hawkins: I don´t know what milage is on the R100. But what I know is that nobody loved the  bike before.
There was no clearance between the exhaust valve and the rocker of the of the right cylinder. So the ventile never closed correctly. The second point is the condition of the carbs. I don´t believe that they worked as they should.
I replaced everything inside the carbs.
I found the  A.T.E . brakes in this condition:
Those are the same calipers. I only cleaned them
The wheel bearings looked like that.
I´m sure the R100 has never had any services or maintenance. This is the old air filter.
I hope I will get her back on the road again.
CU
Dirk
Re: I´m still alive
« Reply #43 on: March 24, 2009, 08:33:35 PM »
See Dirk, that's what happens when you let one of our bikes live under the ocean for a while.  Wow, that was bad.  Good luck with the resurrection!
trolle
Re: I´m still alive
« Reply #44 on: March 25, 2009, 03:32:44 PM »
Trolle,
Good job Trolle!
She will always be the wh8la2, she just got her a nice new dress ;) :-)
Dirk, that is one neglected bike you have got there. What do you use to clean the aluminimum?
greetings from a freezing north
