Author Topic: cables  (Read 1518 times)
awaffa2003
cables
« on: January 24, 2008, 06:31:30 PM »
I just put clipons on from having the U.S. "high bars. should I get new cables or route them differently? my throttle is fine and snaps back better than ever, but my choke is VERY hard i can't even get it choked all the way. if I could make a pair of those independant pull tab chokes that would be better...anyone rig something up???
airhead
Re: cables
« Reply #1 on: January 24, 2008, 06:57:04 PM »
Why bother with choke actuator/cables at all??
Another way is to have a pull wire with loop to actuate the enricher on just one carb, the left usually. Only one carb so rigged is sufficient, and no return spring is needed if the wire is chosen carefully and installed with a little stiction. I haven't tried it myself, but others swear by it. Here's a pic of one installed an an R100 that the owner is currently riding around the world. He said it has never failed to start, and saves complexity on his machine, a purpose built sidecar made for all conditions. This enables him to also run a spare throttle cable running where the choke cable would, which can be seen in the background ready for instant changeover.
Bill.................;-)
« Last Edit: January 24, 2008, 07:00:16 PM by airhead »
Jon_P
Re: cables
« Reply #2 on: January 25, 2008, 08:02:53 AM »
thanks for sharing that Bill, i know what i am going to do with my choke cables now, retire them to the extra pieces drawer.
Re: cables
« Reply #3 on: January 25, 2008, 01:32:24 PM »
Personally, I like the on handle bar choke control as long as they are properly adjusted.  But, I can see the lure of saving an ounce to some of you minimalist guys! ;)
Re: cables
« Reply #4 on: January 26, 2008, 03:13:15 PM »
tagordon said (before I split the thread):
"As for the choke cables being too tight. Check the coupling under the tank, where the the one cable becomes two.
I had to readjust mine carefully to get things working properly. After rerouting the mess of wires & cables that I inherited from PO of my R100."
tagordon
Re: cables
« Reply #5 on: January 27, 2008, 07:03:55 PM »
Thanks. So, I wonder. Did he check the junction for adjustment?
Re: cables
« Reply #6 on: January 28, 2008, 12:32:06 AM »
I'll bet he is right now, which would explain why he hasn't replied in a while!  ;)
awaffa2003
Re: cables
« Reply #7 on: January 29, 2008, 08:59:55 PM »
lol no i didnt check the cables i just kinda yanked them out and made my own choke levers. ill post pics asap.
awaffa2003
Re: cables
« Reply #8 on: February 05, 2008, 07:31:48 PM »
Problem solved!!! I used some thick coat hanger and cut it from the 2 straight parts on top that are at an angle, sanded them down to bare metal, cut off the hollow screw thing from my cables and you can tell the rest from the pics.... one's kinda blury but you can see how I hooked the rod around.
my cables and you can tell the rest from the pics.... http://hs.facebook.com/album.php?aid=13371&l=572d1&id=533986563
awaffa2003
Re: cables
« Reply #9 on: February 05, 2008, 07:35:18 PM »
OH lol I just checked the link to make sure it works and just so you know, that would be me in the pic in the upper left corner. click the pic to go to my other albums... 8-) ;)
