Author Topic: HID fogs...  (Read 3331 times)
HID fogs...
« on: November 17, 2007, 08:20:55 AM »
I'm getting a mental image of a pair of these on the front of my RT...
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=95058
tagordon
Re: HID fogs...
« Reply #1 on: November 17, 2007, 08:43:48 PM »
I say go for it. You can field test em for the rest of us.
I would like to know all the specs. The OD, length frt-bk, Ampre draw, replacement bulb part#, etc.
It gets dark here @ 5pm now. I go to work in the dark & come home in the dark.
Sometimes I think I am in the dark @ work as well.
Good thing I ain't a'scared the dark.
Some extra light would be nice.
Re: HID fogs...
« Reply #2 on: November 18, 2007, 12:24:24 AM »
...and let us know of the cops give you any trouble!
The specifications are in the product manual.  Go to the link Justin posted, and click the Download Product Manual button.  3 amps = 36 watts at 12 volts, I believe, which is way less than the 110 watts that my pair of (much cheaper!) H3 running lights draws.
I wish all these lying light makers would give us some objective measurements of light output, like lumen.
scottyintex
Re: HID fogs...
« Reply #3 on: November 18, 2007, 08:41:48 AM »
OK,...this has my attention.........would love to see how they look on you cycle and learn how they work........what problems......if any that you have...update please.
Re: HID fogs...
« Reply #4 on: November 18, 2007, 09:45:04 AM »
Ed, it would be nice as power consumption of an HID lamp can't really be used to compare against an incandescent bulb.  From casting around on the net I have found:
- A 35-Watt XENON HID lamp produces up to 3x the lumens at the light source when compared to a 55-Watt halogen bulb.
- A 24 watt HID bulb provides 1300 lumens of light.
- A 35 watt HID bulb provides 2800 lumens of light.
-  An HID bulb provides about 3x the light of a high performance halogen bulb of the same wattage...
- NO XENON HID conversion kit available from any source is DOT approved if installed outside of the factory.   This means HID conversion kits are not street legal for use on public in the U.S.  This applies to kits that convert your existing headlight.
Re: HID fogs...
« Reply #5 on: November 18, 2007, 09:50:35 AM »
I'd have a hard time paying $180 for something  from Harbor Freight, that didn't weigh at least 500 pounds.   ;D
Re: HID fogs...
« Reply #6 on: November 18, 2007, 10:10:03 AM »
Re: HID fogs...
« Reply #7 on: November 18, 2007, 11:19:44 AM »
Do people actually pay $900 for a set of after market lights ?    :o
When I got the PIAA 510's for the oilhead, I thought $180 was a high price !!!
My personal favorite is the PIAA 40 round series, too large for most bikes, 6.25 inch ( 160 mm ) reflector.
They look out of place on the crash bars on the R65, but with PIAA superwhite lamps installed, you will never go wanting for extra light.
Though you may be needing a high output alternator after stressing the 27 year old charging system  too much!
« Last Edit: November 18, 2007, 11:33:27 AM by Bob_Roller »
Re: HID fogs...
« Reply #8 on: November 18, 2007, 12:11:45 PM »
If I were making a custom bike I would go with a pair of these in lieu of headlights:
http://trailtech.net/frame_mounted_hid_scmr16.html
But I'm sure they too are not street legal.
Here's a daydream:  a way to aim my mirrors so as to direct the reflections of the too-bright headlights of somebody behind me, right into their own eyes.  Some local idiot in a Jeep has been behind me twice with his (I presume) low beam headlights so bright that I couldn't see where I was going, so I had to pull over and let him go by.  In a car with the rear view mirror on the night setting it's not so bad, buy my bikes don't have that.
Re: HID fogs...
« Reply #9 on: November 18, 2007, 06:12:55 PM »
I am also curious how well these work out for you, Justin.  I've considered adding some HID lamps myself, as they could definitely be gentler to the charging system than Halogens of anywhere close to the same light intensity.  Please let us know !
Re: HID fogs...
« Reply #10 on: November 18, 2007, 06:51:17 PM »
I guess I'll start putting my e-Bay proceeds into a "pot" to buy lights with...
Re: HID fogs...
« Reply #11 on: November 19, 2007, 12:52:22 PM »
For all of you that would like to "update" their current headlight from H4 to HID there are numerous kits on the market.  Originally, these conversions forced you to "loose" your high beam but there are now "dual" kits so you don't have to sacrifice anything.  I have corresponded with the folks at Omega Xenon and they verified one automotive kit has enough "important" bits to convert two motorcycles.
If some of you would like to do that then you could split the cost of a kit and save some bux over what some sellers gouge for a motorcycle kit.  Funny, some of the sellers offer a motorcycle kit (which is half of a car kit) at considerably more than 1/2 the cost of a car kit...
The Omega Bi-Xenon kits contains both a high and low beam so at $390 would make it $195 per motorcycle:
http://www.omegaxenon.com/catalog/item/2271500/1709614.htm
« Last Edit: November 19, 2007, 03:35:23 PM by admin »
Re: HID fogs...
« Reply #12 on: November 20, 2007, 11:04:14 AM »
I've been curious about these:
http://tinyurl.com/37rodr
They won't fit my R65, as the Windjammer uses a 7" sealed halogen, but I'm wondering if I could make it work on my positive ground Triumph, especially as it only has a 120 watt alternator.  I'm assuming the mechanical portion is the wink point of that bulb.
Re: HID fogs...
« Reply #13 on: November 20, 2007, 04:46:25 PM »
I have seen replacement 7" headlamp units which take an H4 bulb...
Re: HID fogs...
« Reply #14 on: November 20, 2007, 05:51:46 PM »
Ed, something like this may be what you need:
http://www.commandocaralarms.com/itemdetails.asp?ProductID=1033
