Author Topic: headlight and  dash assembly  (Read 741 times)
milkman
« on: January 09, 2008, 10:26:18 PM »
Greetings all ,
I finally took the bikini fairing off my LS,  and things aren't great......
 the frame that holds teh headlights, gauages and teh X bracket of teh brake and clutch lines on is rusted silly and cracked completely through on one side
I dont have teh original LS fairing, and was going to saty naked.
SO what have others done? I was going to attach a normal set of headlight ears, but what did others do to attach teh original gagues? OR will I have to manufacture something up, or just chase up a dash fram from teh wreckers?
Re: headlight and  dash assembly
« Reply #1 on: January 10, 2008, 09:33:34 AM »
I have lost the front clock/headlight assembly completely and just run a push bike speedo...The orignal headlight is attached by an aftermarket set of ears and the speedo to the back of that.  I have a separate dash with the ignition and idiot lights.  I do not feel the need for a rev counter, so I did not fit one.
You can now buy some rather clever electronic rev counter/speedos with idiot lights from the following site:
http://www.dirtbikedepot.com/shop/erol.html
Hope this helps
« Last Edit: January 10, 2008, 09:34:24 AM by steve_hawkins »
