Author Topic: Driving Light Relay  (Read 1396 times)
Offline Kelvin
  • R65LS
Driving Light Relay
« on: April 07, 2020, 09:56:28 PM »
My COVID project #2: install the driving lights that have been in a box for a year.
My bike is European spec and has no headlight relay. I’ve run a 55/100W headlight bulb for 20 years not realising that all that current goes through the handlebar switch, but I’ve never had a problem.
The new driving lights are 10W each, so 20W. That should draw 20/12=1.7Amp. So, I should be able to power these off the high beam terminal in the special equipment connector. I have a rig with a switch and a 3A fuse. And, I’ll cut the headlight bulb back to the standard 55/65W.
Does anyone see a problem with this? It seems straightforward, but normal practise is to use a relay when you install driving lights, so I’m a bit uncertain.
Thanks in advance.
1983 R65LS 1985 to 1988
1983 R65LS 1996 to present.
1983 R65LS 2024 to present.
1984 R65LS 2019 to present.
1985 K75C 2023 to present.
Offline skippyc
Re: Driving Light Relay
« Reply #1 on: April 08, 2020, 07:55:10 PM »
Power wise i wouldn't have a problem with it.
« Reply #2 on: April 11, 2020, 03:44:35 PM »
Even though the USA spec bikes have a head light relay all the current still goes through the head light switch
The relay only breaks the circuit during starting
Personally I think it is safer to run the head light through a load shedding relay that is controlled by the handle bar switch
I would elaborate more if I was on the computer instead of my phone
Mrclubike
Offline dogshome
« Reply #3 on: April 21, 2020, 01:48:55 PM »
If they are the LED type, they don't draw as much as that. Chinese Sales "20W (USD)" means 10W (GBP) but actually very bright and useful.
https://www.bmwr65.org/YaBB2.612/cgi-bin/yabb2/YaBB.pl?num=1572979773/10#10
« Last Edit: April 21, 2020, 01:49:34 PM by dogshome »
« Reply #4 on: April 26, 2020, 11:32:46 AM »
I've gone to additional relays for headlight and driving light use .
Not difficult to do at all .
Less costly  for the relay and wiring than it is for a replacement head light switch assembly !!
« Reply #5 on: April 27, 2020, 06:55:26 AM »
And they are made from unobtainim these days ... So beware !
