Author Topic: Starter or starter relay issue?  (Read 2369 times)
Offline r67boxer
  • Inactive
« on: April 25, 2020, 05:07:36 PM »
I finally got to the point of trying to start my now assembled '87 R65 basket case. All I hear is a loud click. I checked the battery and both (I tried another too) are fully charged. Figured it was the starter itself so I changed that one out too with a freshly rebuilt one. Same 'click'. Terminals on the battery and starter are tight. I don't have a spare relay so can't try that out till I get another. Any ideas?
Online georgesgiralt
Re: Starter or starter relay issue?
« Reply #1 on: April 25, 2020, 11:15:48 PM »
Hello r67boxer,
Do you have a multi-meter ?
If yes, check that when you press the starter button, you have a +12 V at the spade connector on the starter. This is the signal for the starter to run. If yes, this will said that the relay is sound. If not, either the relay or the wiring are at fault.
If you have the 12 V coming to the starter, you may have the solenoid either not working or the contact oxidized inside.
You can also test the starter outside the bike using the plus and minus cables from the battery but hold the starter firmly in a wise because if it starts it will jump fiercely....
Hope this helps.
P.S. : if you do not have a multi-meter, you can check using a 12V bulb and a couple of wires... The bulb should light ...
Offline r67boxer
  • Inactive
« Reply #2 on: April 26, 2020, 08:05:02 AM »
I'll check that out this afternoon. Thanks.
« Reply #3 on: April 26, 2020, 08:52:00 AM »
If you remove the plugs and put the bike in 5th gear on the center stand, can you rotate the engine by turning the rear wheel?
« Reply #4 on: April 26, 2020, 11:17:07 AM »
Is the click you hear coming from the starter or the starter relay ??
Offline r67boxer
  • Inactive
« Reply #5 on: April 26, 2020, 12:55:18 PM »
Starter. A loud click/clunk.
WRT the earlier question, yes I can turn the engine over manually.
Okay, I just checked the relay, positive to the battery and negative to the spade connector and I had 12.4 volts.
« Last Edit: April 26, 2020, 01:05:20 PM by r67boxer »
« Reply #6 on: April 26, 2020, 01:12:46 PM »
Kinda sounds like a battery issue .
How old is the battery ??
Can you put jumper cables from another vehicle to the bikes battery and see if the starter works then ??
Offline r67boxer
  • Inactive
« Reply #7 on: April 26, 2020, 01:48:54 PM »
I bench tested the starter and it works. Not sure what to do next save for wiring. Everything is tight.
« Reply #8 on: April 26, 2020, 03:03:45 PM »
When you engage the starter, what does the battery voltage drop to .
Offline r67boxer
  • Inactive
« Reply #9 on: April 26, 2020, 03:45:03 PM »
It drops off to 11.6 V when the starter button is engaged.
« Reply #10 on: April 26, 2020, 04:04:44 PM »
Only thing I can think of that may cause this, is the contacts in the solenoid  .
Possibly there are a few peaks on one side caused by metal transfer, you get enough power to operate the solenoid, but can't get enough current flow to rotate the starter when installed in the engine with a heavy load trying to move the engine.
Offline r67boxer
  • Inactive
« Reply #11 on: April 26, 2020, 04:34:00 PM »
Thanks. The bizarre part is that I've tried 2 starters. One recently professionally overhauled, the other in the R65. Both do the same on the work bench and make the same 'click/clank' when installed.
I tried to manually turn over the starter while installed and could not get it to turn when I shorted between the nut (where red wires go) to the spade connector. Ignition was on.
« Last Edit: April 26, 2020, 04:35:14 PM by r67boxer »
Offline r67boxer
  • Inactive
« Reply #12 on: April 26, 2020, 04:48:14 PM »
I just looked at the wiring diagram and this bike (1987) has a clutch switch which presumably will not allow the starter to be engaged without depressing same. I've tried both with and without depressing the clutch with the same outcome. What if the clutch switch is bad?
« Reply #13 on: April 26, 2020, 05:15:25 PM »
If the clutch interlock switch was bad, there would be no power to the starter no clunk when the start switch is depressed, it removes a ground for the starter relay .
« Reply #14 on: April 26, 2020, 05:28:12 PM »
I'm running out of ideas about this !!
There has been issues with the battery cables at the battery usually the positive cable, corrosion under the insulation .
http://motoelekt.com/chassis.htm
