Author Topic: Straightening snowflake wheels  (Read 1815 times)
Offline davidpdx
« on: November 09, 2019, 01:27:54 PM »
Has anyone had any experience with straightening snowflake wheels or having them straightened by someone else. My front wheel has experienced a bad hit at sometime in it's life and has quit a bulge on both sides. It does not cause much of a handling problem as long as I keep my tire inflated to 38 or so but if I back the pressure off to 32 or so it gets noticeable.   Thanks, David
1984 R65 60K+
1946 Triumph Speed Twin
? Hunter S. Thomps
Re: Straightening snowflake wheels
« Reply #1 on: November 09, 2019, 01:58:26 PM »
I have not had any wheels straightened, but about  a yesr ago I was at the local BMW car delership getting parts for my Z3 .
There was a large trailer that had wheel straightening on the side, the two people were straightening auto wheels .
I asked if they worked on motorcycle wheels, specificly older BMW wheels .
One of them said they had, the older snowflake wheels are quite soft and easily reworked as long as they were not cracked .
Might want to try contacting a local BMW car dealership and see if they this work done by a similar type business .
Offline wilcom
« Reply #2 on: November 09, 2019, 02:07:41 PM »
Woody's wheel works does straightening.
https://woodyswheelworks.com/
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Offline davidpdx
« Reply #3 on: November 09, 2019, 04:26:57 PM »
Thanks for the ideas. Now I just got to get my ass in gear and take the wheel off.
1984 R65 60K+
? Hunter S. Thomps
« Reply #4 on: November 11, 2019, 05:12:58 AM »
Yes it can be done.
the wheels on my wife's bike were straightened after she found a massive pothole and the rear is still on that bike.
The front got damaged in the accident I had on it and it now has the front from the 1984 edition I bought to supply the parts needed to repair her bike.
Recently I delivered a very bent (and cracked) LS rear wheel to a local engineering firm and it is now welded up and straight - they are going to heat the entire wheel and then let it cool to ensure it remains straight. This was an expensive job, but I also asked them to look at the original front wheel from my wife's bike - the quote is $85 to straighten it.
I believe that they mount the wheel in a big lathe and use wooden "bucks" to press it straight, but I am not certain on this and it is a black art closely guarded secret.
All I can suggest is to ask to see before and after photos of their past work.
« Reply #5 on: November 11, 2019, 12:36:02 PM »
Hello,
My local BMW Guru straitened one front wheel on my R65. I had two, one was "not salvageable" by it's words.
So yes, it is possible and was done....
