Author Topic: bad to worse  (Read 1440 times)
chris_blake
bad to worse
« on: December 15, 2007, 05:15:15 AM »
managed to remove clutch piston and bearing both are fine no pitting bearings move freely i can now see what you mean about the rod i will have to get some sort of screw or bolt in but i think the swingarm will have to be removed anyway i thought i would try a test ride just to check on starting the bike i got a loud grinding noise from i think the starter motor as soon as i turned on the ignition without pressing the starter button this then stopped i pushed the starter button and bike started when i twisted the throttle it made the noise again as if the starter motor was trying to turn also when this occured the headlight went off  this happened 4 or 5 times and then stopped  once the engine was warm i could not get it to repeat it could it be a faulty starter relay or is it linked to the clutch problem any advice as always much appreciated i am beginning to think this bike has had a pretty hard life with its previous owner even though it is low mileage only 22'000 miles
Re: bad to worse
« Reply #1 on: December 15, 2007, 06:55:44 PM »
I had a similar occurance that you described, it happened after I washed the bike, I blew out the starter switch with compressed air, and it never came back.
If your headlight goes out when this happens, the lighting relay is de-energized when the starter is activated by the start switch and starter relay.
chris_blake
Re: bad to worse
« Reply #2 on: December 16, 2007, 12:15:47 AM »
thanks bob when you say the starter switch do you mean the starter button
Re: bad to worse
« Reply #3 on: December 16, 2007, 09:14:36 AM »
Yes I meant start button, I have an aviation maintenance background, and tend to call things more in a technical sense than it really needs to be outside of work.
tagordon
Re: bad to worse
« Reply #4 on: December 16, 2007, 11:54:59 AM »
FWIW
I know a R65 rider that had the starter engage while at traffic speed. Destoryed the flywheel & starter completely.
He said it happened briefly a couple times before the destructive occurrance. But he did not know what the noise was.
« Last Edit: December 16, 2007, 11:56:13 AM by tagordon »
chris_blake
Re: bad to worse
« Reply #5 on: December 16, 2007, 02:20:35 PM »
followed your advice bob and it started fine this seems to be temperature related  i will keep you infomed as we are due some pretty cold weather due this week thanks again'
