Author Topic: Starter Trouble  (Read 1898 times)
Offline vtmando
Starter Trouble
« on: June 09, 2019, 04:58:18 PM »
82 R65...just put battery in after storage in warm dry basement. Will not engage starter...lights work but all I get is a "click" and starter doesn't turn or engage. Is this a battery problem or starter? Help!!
1982 R65 ?
1973 R75/5
Offline skippyc
Re: Starter Trouble
« Reply #1 on: June 09, 2019, 05:35:02 PM »
If the lights go out when you hit the starter then it a power problem, if not it's a starter problem.
That said it can be a poor connection faulty relay. A multimeter is a good way of checking voltages in the system when the starter is pushed.
Online Bob_Roller
Re: Starter Trouble
« Reply #2 on: June 09, 2019, 05:41:40 PM »
North American R65's have a relay that turns off the headlight, when the starter is used .
Do you have a multimeter to check the voltage of the battery ?
Was the battery sitting fpr a long time without being on a charger of some sort ?
« Last Edit: June 09, 2019, 05:54:12 PM by Bob_Roller »
Offline vtmando
Re: Starter Trouble
« Reply #3 on: June 10, 2019, 06:47:14 AM »
Yes battery sat in my basement for the winter without a charge...I'll get a multimeter today...I'll get back with results.
Thanks!
1982 R65 ?
1973 R75/5
Offline vtmando
Re: Starter Trouble
« Reply #4 on: June 10, 2019, 07:59:13 AM »
Headlight goes out when I try to start...loud strong click but starter doesn't engage.
1982 R65 ?
1973 R75/5
Offline donbmw
Re: Starter Trouble
« Reply #5 on: June 10, 2019, 08:28:53 AM »
Sounds like a low battery.
Offline vtmando
Re: Starter Trouble
« Reply #6 on: June 10, 2019, 11:54:56 AM »
Thanks all...got it!! loose battery connection!! I feel a bit stupid...I was in too much of a hurry to ride! ;D
1982 R65 ?
1973 R75/5
Offline tiggum
Re: Starter Trouble
« Reply #7 on: June 10, 2019, 01:21:37 PM »
We all understand, but be careful......think of all the other bolts you might not have installed properly, and go over it meticulously.
