Author Topic: Starter lube?  (Read 1189 times)
Offline Jschara
Starter lube?
« on: June 02, 2019, 10:06:53 AM »
I recently remover my starter on my 1979 R65 to replace the battery cable and line from starter to the diode board.  My question is should the shaft that the pinion gear slides on be lubed?  And if so, what type of oil, grease should be used.
Thanks,
Jim
Re: Starter lube?
« Reply #1 on: June 02, 2019, 12:16:18 PM »
A light grease, don't use too much, it will just make a mess in the area if you do .
You've got a 40 year old starter, most likely all the lubrication in the starter is gone .
Don't know your capabilities, but if you can get oil at each end of the starter shaft bearings, they are a sintered type, granulated brass material that is pressed into a bearing, some engine oil or similar oil will help out .
Oil will be absorbed into the bearing material .
« Last Edit: June 02, 2019, 12:29:11 PM by Bob_Roller »
Offline Jschara
Re: Starter lube?
« Reply #2 on: June 02, 2019, 05:47:10 PM »
Thanks Bob,
Jim
