Author Topic: Fuel tank level gauge  (Read 1895 times)
Offline Sejati
  • 1982 R65LS
« on: May 12, 2019, 07:44:08 AM »
I use 1982 R65LS, which currently under recondition.
Does anyone here have made modification on the Karcoma fuel valve into type with level sensor or level switch ? So we could take this signal into electronic gauge for fuel level information or low level warning light.
Would love to have anyone comment on this kind of modification.
Cheers.  :)
Online Bob_Roller
Re: Fuel tank level gauge
« Reply #1 on: May 12, 2019, 10:20:04 AM »
Never  heard of anone trying this .
Offline donbmw
« Reply #2 on: May 12, 2019, 01:32:02 PM »
Just go by mileage. You should have 30 to 40 miles when you hit reserve.
« Reply #3 on: May 12, 2019, 05:07:50 PM »
Know your bike. Know how many km (miles) you can do before turning the reserve on. And if it came early, you'll know something's wrong.
« Reply #4 on: May 12, 2019, 06:56:42 PM »
A fuel level gauge would be good to have but the trip meter works just fine
« Reply #5 on: May 13, 2019, 03:55:14 AM »
I've got used to how far it will go on the 2 Litre reserve but have run out of that a couple of times. It's not a problem though as there is at least another 1/2 litre on the right hand side of the tank which can be transferred to the left either by lying the bike down or as I now do in my old age, lifting the tank and  tipping it over to the left. I don't remove the fuel hose to do this so it's an easy operation.
Offline Sejati
  • 1982 R65LS
« Reply #6 on: May 14, 2019, 10:31:07 AM »
Thanks for anyone feedback on this thought.
Glad to know a potential reserved fuel from right to left side of tank. :)
I’ve lost my trip mete (haven’t check on this issue)r, so I’m blind on the quick distance view.
Offline ged in oz
« Reply #7 on: May 14, 2019, 04:16:44 PM »
Trip meters/odometers failing seems pretty common on R65’s and there are some fixes available on line.
Barry has started a thread in this section on the same issue so you might want to keep your eye on that too. Hopefully all of us will come up with a solution.
« Reply #8 on: May 16, 2019, 08:18:17 PM »
If all else fails you can hand cut new gears out of delrin or brass using hand tools, see https://www.youtube.com/watch?v=uxzWk7v9sUo
Or, you could contact Lionel Otto Instruments in Brisbane who will be happy to considerably lighten your wallet, but who do 1st class work.
Offline Sejati
  • 1982 R65LS
« Reply #9 on: May 21, 2019, 11:48:30 AM »
Does anyone has reference what is the size of Karcoma thread to the fuel tank, and its thread pitch size ?
