Author Topic: Fork seal replacement on r65LS  (Read 2161 times)
Offline jamestnewsonr65
« on: April 04, 2019, 04:21:09 AM »
A pesky small tear in one of my fork oil seals decided to spray sticky fork oil all over my left side...
My question is to replace the seal I can just take off the lower leg, replace the seal and refit... Do I need to take the complete leg off though to fit the lower allen bolt as it won't snug up, just spinning with the internals.
Thanks for any replies. I can't remember what I did when I rebuilt them 5 years ago.
1981 R65 (box of bits).
Re: Fork seal replacement on r65LS
« Reply #1 on: April 04, 2019, 06:24:30 AM »
To tighten up the Allen bolt try compressing that fork leg which will press down on the damper rod piston and help stop it from spinning.  If you had a impact gun that would also work.  If all else fails you need to remove the spring and use a socket on a long extention to hold the damper piston still while you tighten the Allen bolt.
Edit:
Even if you use the socket method, overtightening the Allen bolt can have interesting results. One time when I was dismantling the forks, instead of the Allen bolt unscrewing the whole damper rod unscrewed from the damper piston.
« Last Edit: April 04, 2019, 06:33:24 AM by bhodgson »
« Reply #2 on: April 04, 2019, 06:28:30 AM »
13mm socket.
And hope that the whole top of the damper rod doesn't unscrew. That is a PITA.
« Reply #3 on: April 04, 2019, 06:32:31 AM »
You beat me to it while I was editiing Tony.  Yes it was PITA.
« Reply #4 on: April 04, 2019, 03:08:34 PM »
Thanks for the replies. I'll try the impact driver on it and if that doesn't work then I'll take the assembly out and get a long extension.
Thanks as always.
« Reply #5 on: April 04, 2019, 05:10:19 PM »
Thanks for the replies. I'll try the impact driver on it .
When you say "impact driver" I hope you mean "air impact wrench" aka 'rattle gun'.
If you mean an impact wrench that you smack with a hammer - they are good devices, but this is not their bailiwick, don't even bother - pull the spring and start borrowing socket extensions.
« Reply #6 on: April 04, 2019, 05:11:32 PM »
Hello fellow sufferer.   My damper rod tops are now secured with Loctite green.
« Reply #7 on: April 05, 2019, 09:24:02 AM »
Yeah I meant Air impact wrench. Not the one you whack with a massive hammer :)
