Author Topic: Wiring for rev counter  (Read 1162 times)
Offline Sharky
« on: January 28, 2019, 07:19:40 AM »
The rev counter on my bike wasn’t working when I bought it, and with looking inside Speedo housing I found the rev counter wiring disconnected. Any idea which wire goes where to the spade connectors?
1986 R65 mono
Re: Wiring for rev counter
« Reply #1 on: January 28, 2019, 03:04:11 PM »
Hello,
I've found on an old French service bulletin the wiring of the electronic tacho to replace the mechanical one.
The tacho has 3 wires : Red is +12 V Brown is ground and green is impulse from the ignition.
With a multi-meter you should be able to find where are the first two going and, then, find the place for the third...
Hope this helps.
Offline Sharky
« Reply #2 on: January 29, 2019, 04:14:45 AM »
Thanks for info, I’ll give that a go.[ch128077]
1986 R65 mono
