Author Topic: Safety Bars  (Read 1296 times)
Safety Bars
« on: January 01, 2019, 06:44:25 PM »
I put these on today
I was happy when I found these because they are supposed to fit all Airheads
I am a little concerned about them blocking air from the heads but the opinion on ADV rider has been its not a problem
I had to lower them a little so I could get the leg guards on at the same time
I take the leg guards off in the spring
They are just to hot in the warmer climates but the are a God send when it is cold
« Last Edit: November 06, 2020, 08:56:17 PM by Justin B. »
Re: Safety Bars
« Reply #1 on: January 01, 2019, 06:46:00 PM »
I found a picture of OEM guards on a GS and they cover the heads also
« Last Edit: November 06, 2020, 08:57:30 PM by Justin B. »
Re: Safety Bars
« Reply #2 on: January 01, 2019, 06:53:16 PM »
Side View
Re: Safety Bars
« Reply #3 on: January 03, 2019, 04:31:39 PM »
I put a set of Luftmeister  crash ars on my '81 R65 in '82, looks the same as your set .
No issues with engine cooling .
I had mounts welded to the bars for driving lights .
I put PIAA 40 driving lights on .
Re: Safety Bars
« Reply #4 on: January 04, 2019, 02:52:36 PM »
Our '84 has Luftys as well, no problem.
Re: Safety Bars
« Reply #5 on: January 07, 2019, 04:29:40 AM »
There's just been a long debate on the Airheads list about safety bars with several claiming they can bend the frame in a spill due to the long leverage on the mounting points. If that's the case, replacing valve covers after a spill would be much cheaper.
My bike came with them fitted but I removed them 12 years ago. What persuaded me to do that at the time was  Duane Ausherman's view that they could cause a high side in in spill.  He claimed that every bike that came into his shop after a spill had higher repair costs if it had safety bars.  Secondly the extra width wasn't helping squeeze past my car in the garage. I hadn't even thought about bending the frame.
« Last Edit: January 07, 2019, 04:31:36 AM by bhodgson »
