Author Topic: Steering Damper  (Read 2070 times)
Offline Adrian
  • The Old Hairy Biker Sez...
Steering Damper
« on: November 21, 2018, 03:15:13 AM »
Hi there - I am considering fitting a steering damper to my R65. I have seen that a few guys have them fitted - and it seems that they have them to help combat our less than perfect roads.
So what opinions are there - experiences - advice ????
I would be grateful for any thoughts on this - thanks .....
1984 R65 (860)
Re: Steering Damper
« Reply #1 on: November 21, 2018, 04:20:51 AM »
I'm sure someone will have fitted one but I don't believe they are very common on an R65.  Provided  there is a slight pre-load on the steering stem bearings I find there is no real need for any further damping.
« Last Edit: November 21, 2018, 04:22:37 AM by bhodgson »
Re: Steering Damper
« Reply #2 on: November 21, 2018, 02:38:00 PM »
I agree with Barry in that I have never felt the need for a steering damper on the R65.
That said the parts fiche reveals the existence of stock parts to mount a steering damper and I have dim recollections of someone in the group discovering that they are all still available in the course of fitting a damper to their bike.
Re: Steering Damper
« Reply #3 on: November 21, 2018, 02:41:09 PM »
I have one, never installed it on a bike, got it in one of the boxes of spare parts for the '84 LS .
From what I can tell the damper from the damper I have, it's non-adjustable, and only dampens with very quick movement .
There's is a threaded hole on the bottom side of the lower triple clamp, right hand side, that seems to be the forward attach point, but no idea where it would mount to the frame, there are extra holes in the horn bracket, possibly it mounts there .
« Last Edit: November 21, 2018, 02:44:10 PM by Bob_Roller »
Offline wilcom
Re: Steering Damper
« Reply #4 on: November 21, 2018, 03:05:17 PM »
 BMW R65 steering damper mount points
https://www.youtube.com/watch?v=OjDyLckZrK4
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Re: Steering Damper
« Reply #5 on: November 21, 2018, 03:11:49 PM »
Thanks for the video wilcom !! :)
Dug out the damper, I was wrong, it is adjustable, it was set at the lightest the only time I looked at it 10 years ago .
« Last Edit: November 07, 2020, 08:59:07 PM by Justin B. »
Offline Adrian
Re: Steering Damper
« Reply #6 on: November 22, 2018, 12:53:34 AM »
Thanks guys - I'll live without one  ;)
1984 R65 (860)
Offline tunnelrider
Re: Steering Damper
« Reply #7 on: November 30, 2018, 01:15:17 PM »
Thanks for the pic Bob, until then I didn't know if mine was an aftermarket damper or not.  As you can see from the pic I've recently lost the use of it - initially the E clip and bottom washer must've dropped off and now if I put a new E clip and M8 washer on, the damper outside just pushes past the rubber bush, e clip and washer, leaving the bush on the pivot  and the damper hanging in mid air.  I could put a bigger OD washer on to stop this but the bush is not a tight fit on the pivot pin and there'd be slop in the action, not what it's supposed to be like I'm sure.
I can't remember what was there initially - not sure if there's supposed to be an inside collar between the bush and the M8 pivot pin?  Or if the bush is so old it's flogged out. Bob if you still have it handy, would you mind popping the E clip and taking a picture of the pivot disassembled please?
I bought my bike with the damper already installed five years ago and have used it all the time, so I'm pretty used to it.  I think it's been mounted on the bike most of it's life.  Have to say when it dropped the E clip and hung in mid air I didn't notice it not there but I usually turn it up full resistance and appreciate it when riding high speed (120+km/h) on undulating, turning road and usually have the damper on full riding gravel roads, where I think it helps smooth fishtailing tendencies so that it makes it harder to occur.
« Last Edit: November 07, 2020, 09:01:05 PM by Justin B. »
