Author Topic: Another Battery Question  (Read 2798 times)
Offline Tony Gee
« on: August 08, 2018, 08:07:02 AM »
Hi, I've just bought a 1980 R65 that's been standing in a garage for some 20 years and, oddly enough, needs a little work to recommission it!
I've been busy collecting data for this make and year and I'm having problems finding out what battery was originally fitted to it and what suitable alternatives there are available now. I've found that the space restrictions in the "battery compartment" seem to rule out some of the ones that have been recommended by local retailers.
Can anyone shed any light on this, please? I'll, no doubt, figure this out in due course along with how I can get the locking fuel cap unlocked (I've tried the key!!)
Thanks for your help and for letting me join the Forum.
Regards,
Tony
Offline wilcom
Re: Another Battery Question
« Reply #1 on: August 08, 2018, 08:22:31 AM »
This the battery I use in my R65. Probably not available in the UK but the dimensions are there
https://www.gruberpower.com/12-volt-18-amp-hour-ah-battery
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Offline Matt Chapter
  • <insert witty remark here>
« Reply #2 on: August 08, 2018, 09:50:56 AM »
There's a trick to the fuel cap when it gets stuck, I don't know it (cause the monoshock one is better?) but you can probably find it here with a search.
'04 R1150 RT ~41000 miles
Offline jp9094
« Reply #3 on: August 08, 2018, 04:07:33 PM »
This is from memory, and I would research it first! Pass a rope through the fuel cap handle. Tie both ends together (leave enough length)  loop around your neck while sitting on bike. Stand up on pegs and pull the cap out like a cork from a bottle!  Hope this helps.
Regards !
« Reply #4 on: August 08, 2018, 08:53:29 PM »
Search PC680 and that will bring up all kinds of batteries
AGM type is the best way to go
« Reply #5 on: August 08, 2018, 08:55:18 PM »
Moto bins has this
« Reply #6 on: August 09, 2018, 08:26:46 PM »
I used to use the PC680 until the price got crazy then I switched to the Universal and never looked back.
« Reply #7 on: August 10, 2018, 06:10:08 PM »
I got my first PC680 battery in 1999 paid $65 delivered to my home .
The last one I bought was $120 delivered, and lasted 25 months, that's when I switched to generic AGM batteries .
The unrelenting heat here in the low desert usually kills motorcycle batteries in less than three years, no matter what you purchase .
« Last Edit: August 10, 2018, 06:10:46 PM by Bob_Roller »
Offline Burt
« Reply #8 on: August 10, 2018, 08:25:51 PM »
For the fuel cap wrap a rag around 360 degrees under the lip and apply pressure upwards.  Assuming you have unlocked the cap (50/50 chance here).  Then with the handle turn the cap until it starts to unscrew.
If the internal "link" is broken it will not turn so you need to apply the upwards pressure on the lip.
You can buy a new cap (expensive) or drill and put a small bolt in the cap which means you can not lock it anymore.  I hope this makes sense.
Black 1984 R65 - the Wombat
« Reply #9 on: August 10, 2018, 09:52:18 PM »
FYI
My Odyssey is almost 4 years old with over 40000 miles on it
No sign of failing  :)
I wasn't really pushing the Odyssey battery
I already know everyone on here thinks they are to expensive  :o
I was just saying  if you search "PC680" a lot of options will come up
« Reply #10 on: August 11, 2018, 12:05:28 AM »
Do not break your cap. they are NLA at BMW ...
Offline Burt
« Reply #11 on: August 11, 2018, 03:21:16 AM »
However, Motorworks have a reproduction item and various other options.
Offline DadsR65
« Reply #12 on: August 11, 2018, 05:33:36 PM »
Regards,
Tony
I use this in my '80 R65:
https://www.amazon.com/gp/product/B00KC39BE6/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
If you're interested, I rebuilt mine last winter:
https://advrider.com/index.php?threads/new-airhead-project.1260761/
« Reply #13 on: August 11, 2018, 05:42:25 PM »
Lots of options available today compared to 20 years ago !! :)
Offline Tony Gee
« Reply #14 on: August 27, 2018, 04:11:09 AM »
Eventually got the filler cap off after pouring loads of WD40 in to release it. It was rusted out, though, so I need to get hold of a replacement. I understand that Motor Works can supply S/H ones without keys which is probably the way I'll go.
Battery was easier, I got an Exide from a local dealer. It fits well and turns the engine over. So that's good.
Thanks for all your help.
Tony
