Author Topic: Airbox Question  (Read 2783 times)
Offline Adrian
  • The Old Hairy Biker Sez...
Airbox Question
« on: November 05, 2017, 07:41:48 PM »
Hi all - the picture shows the airbox internals. I read somewhere that it's not necessary to connect up the plastic/rubber pipes to the engine breather. Is this correct?
I'm just being a bit lazy perhaps but it would be less clutter in the box if it can be left out.
Thanks........ Adrian
1984 R65 (860)
Re: Airbox Question
« Reply #1 on: November 05, 2017, 08:36:22 PM »
Some folks have eliminated all that plumbing by just running a hose from the breather to a catch-can...  All the stuff in your pic dump all the burped out oil mist into the carb intakes so it will burn up.
Re: Airbox Question
« Reply #2 on: November 05, 2017, 09:54:40 PM »
If not installed you will end up with the oil settling in the bottom of the air box and maybe oil on the filter  element
« Last Edit: November 05, 2017, 09:56:16 PM by Mrclubike »
Re: Airbox Question
« Reply #3 on: November 05, 2017, 10:03:30 PM »
Regarding the catch can, this is one of my favorites.
« Last Edit: November 05, 2017, 10:04:00 PM by Rob_Valdez_79_R65 »
Offline Adrian
Re: Airbox Question
« Reply #4 on: November 06, 2017, 12:37:52 AM »
Okay I get it - back in they go ......
Thanks guys .....
1984 R65 (860)
Re: Airbox Question
« Reply #5 on: November 06, 2017, 05:49:43 PM »
You really don't have to.
If you have a catch can, you will NOT have oil all over the place.
You will also NOT have oil dripping on your boot.
« Last Edit: November 06, 2017, 05:50:55 PM by Rob_Valdez_79_R65 »
Offline badgertom
Re: Airbox Question
« Reply #6 on: November 13, 2017, 06:00:19 PM »
To install Clamp on air filters as shown by Bob Valdez do you need to re-jet the carbs. To me it seems that you do since more air is getting into them. Also how would you determine the new jet size? I just like the look. I have the
Bing 46-241. Will I make more problems for myself?
Offline hoverdog
Re: Airbox Question
« Reply #7 on: July 16, 2018, 10:28:34 AM »
This is a question about the rubber valve (Part No. 13721337162) which is in the airbox, which way round is it fitted? mine has completely disintegrated and the remnants were removed when I updated my iron horse. It seems  to be running fine without it though (he said, tempting fate)
1981 R65LS
Past:?
2003 R850R
1995 R80
1982 R100RS
1981 R65
Re: Airbox Question
« Reply #8 on: July 16, 2018, 04:05:45 PM »
Quite simply the bile will never run as well across the entire rev range, or as economically,  with pod filters fitted as it will with the stock air filtration system.
Period!
The very simple reason for this is that the engine requires a "tuned length" intake which the pod filters will not provide.
You can of course re-jet for peak power at WOT, or you can play the endless game of compromise to try and obtain more acceptable running for whatever style of riding you do.
Course you could fit appropriate length velocity stacks and that would solve the problems, but that will involve either inventing and entirely new place to mount foot pegs and controls, and/or a bilateral lower limb amputation that may place restraint on your activities of daily living.
Re: Airbox Question
« Reply #9 on: July 17, 2018, 09:07:56 PM »
This is a question about the rubber valve (Part No. 13721337162) which is in the airbox, which way round is it fitted? mine has completely disintegrated and the remnants were removed when I updated my iron horse. It seemsĀ  to be running fine without it though (he said, tempting fate)
  Install it sticking out of the box or at least plug it with something
If the hole is open you will be sucking dirt in to the intake of the engine
I assume you are talking about #15
Offline peteremc
Re: Airbox Question
« Reply #10 on: July 17, 2018, 09:22:10 PM »
Here's your solution, Tony.
« Last Edit: November 09, 2020, 11:18:01 AM by Justin B. »
peteremc
Offline peteremc
Re: Airbox Question
« Reply #11 on: July 17, 2018, 09:28:39 PM »
In reply to Badger Tom....
I ran the pod filters for a while (without re-jetting) and it seemed to have negligible impact on performance. Not sure about economy. But the thing that worried me the most was the lack of support for the carbs. A couple of hose clamps didn't inspire a lot of confidence. In fact, the left carb came off one day and was left hanging by the choke & throttle cables. I went back to the full airbox for this reason. I still think the pod filters look pretty sexy, though. If a more rigid/reliable system of mounting the carbs was developed I'd go back tomorrow.
peteremc
Re: Airbox Question
« Reply #12 on: July 18, 2018, 02:02:02 AM »
Love it!
Offline hoverdog
Re: Airbox Question
« Reply #13 on: July 19, 2018, 08:10:49 AM »
It is indeed #15, cheers
1981 R65LS
Past:?
2003 R850R
1995 R80
1982 R100RS
1981 R65
