Author Topic: SKID PLATES?  (Read 2386 times)
Offline Luke D.
  • Hakuna Matata
SKID PLATES?
« on: June 01, 2018, 09:08:47 AM »
Good day everyone,  I tried searching and didn't find anything (or I did it wrong :) ) I riding yesterday when my nice paved road turned to not so nice pavement (dirt).  As I was riding and enjoying the views I kept hearing some tink tink tinks.  I know the smaller rocks wouldn't be an issue but it got me thinking about skid plates.  I have a lot of dirt roads where I live that I would love to check out.  Nothing hard or gnarly just fire roads.  So I tried my google-fu for some r65 skid plates....zip zero zilch nada.  :(  I was wondering if any of you fine people have ever put one on or bought or even made a skid plate for your bikes?  Any help is appreciated, thanks all and have a great day.
Dont worry and be happy!
1982 R65LS
Re: SKID PLATES?
« Reply #1 on: June 01, 2018, 09:31:01 AM »
Hello
A friend of mine used an aluminum snow spade to make one...
Add to this that the G/S or GS may had one. As the engine case is the same in that area, maybe on this model there is something available ?
Re: SKID PLATES?
« Reply #2 on: June 01, 2018, 11:50:32 AM »
I looked into it at one time for the same reasons. There are a number of skid plates from GS or G/S models that will work but they all require replacing the oil sump as the attachment points for the skid plate are molded into them. Add to that the fact that there are several oil sumps available in differing capacities and locations  of drain plug. A matched set is required to allow an oil change. Finally GS and G/S parts command a premium on the used market. To me it wasn't worth the expense.
Offline Luke D.
  • Hakuna Matata
Re: SKID PLATES?
« Reply #3 on: June 01, 2018, 12:31:17 PM »
Hey georgesgarlt and marcmax, thanks for the heads up.  I did look out parts for the g/s but was unsure if it would fit.  Another thing I noticed is the attachment points being on the sump/motor, is that smart?  not that I am going off roading and am expecting hits like that but even on a gs wouldn't it be better to attach it to the frame?  I did notice they are quite expensive too and am thinking of making my own ( a bit cheaper).  Playing of the last question about mounting, would it be better to have it mount on the sump?  I was just thinking of using some type of hose clamp to the frame and doing that as it does not have to be really heavy duty just enough for the flinging rocks.  Thanks again for your help, have a great day.
1982 R65LS
Re: SKID PLATES?
« Reply #4 on: June 01, 2018, 12:41:27 PM »
Snow spade used as washer for the engine mounts. Just my 2ยข
Re: SKID PLATES?
« Reply #5 on: June 01, 2018, 10:04:30 PM »
I think it would be an interesting project to design a self-made skid plate. There are several things to take into consideration. 1 is the mounting points - as any major strike will be transmitted up into the frame, motor mounts, etc. 2 is the necessity to drain the oil for an oil change without a major disassembly. 3 it the clearances needed for exhaust crossover pipes, center stands, etc.
Interesting concept that I am willing to jump into again even though my days of venturing down fire trails are far behind me now.
Offline wilcom
Re: SKID PLATES?
« Reply #6 on: June 01, 2018, 10:17:00 PM »
Here's a link to a home made skid plate on a bmw , might give you a few ideas
http://advrider.com/index.php?threads/r80-g-s-skidplate.664801/
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Re: SKID PLATES?
« Reply #7 on: June 01, 2018, 10:30:45 PM »
I really don't think a rock getting thrown up at trail speeds are going to be a threat to your sump
I would be more concerned  what a rock  at high way speeds could do
I think skid plates are meant for dragging the sump over large rocks or logs
The other option is a mud flap
I got this one from   Moto works
« Last Edit: November 09, 2020, 11:46:47 AM by Justin B. »
Re: SKID PLATES?
« Reply #8 on: June 02, 2018, 05:46:32 AM »
Rocks aren't a problem to me but I have a mudflap like that and it goes part way to keeping the muck of the engine in wet weather. It has to be a relatively long like that Motorworks one to do any good though.
