Author Topic: R65 front wheel replacement ?  (Read 2192 times)
Offline 1972R60
« on: May 12, 2018, 04:18:17 PM »
I severely damaged the front rim on my 79 R65. :'( 18" snowflake. Can I use an 18" snowflake from other years? If so, which years or all? How much out of true is acceptable? Any referrals to a possible source? Thanks in advance for your input.
MIBMWNut (Mike)
Re: R65 front wheel replacement ?
« Reply #1 on: May 12, 2018, 05:17:17 PM »
You can use a rim from other year R65's, the early R65 rims were a bit different looking from later years .
I don't know if you have any wheel straightening businesses in your area, I was at the local BMW auto dealership getting an oil and air filter about 6 months ago and one of these mobile services was working on a car rim, I was impressed on how it turned out .
Don't know if there would be issues later on with cracks, etc .....
« Last Edit: May 12, 2018, 05:20:30 PM by Bob_Roller »
Offline 1972R60
« Reply #2 on: May 12, 2018, 06:48:46 PM »
 :)Thanks for the suggestion to straighten the wheel. It will need to be welded first, it is bad, bad. And I understand it can be done locally, but there is a pretty decent delay, and that it can be expensive. :But I will get a price on that too, but I want to get back on the road this year. I only have one bike. Anybody else want to chime in? :-/
« Reply #3 on: May 12, 2018, 08:36:06 PM »
Check in our Trading Post, put a wanted ad in our Trading Post section or keep a watch on fleabay.
« Last Edit: May 12, 2018, 08:58:13 PM by admin »
« Reply #4 on: May 13, 2018, 01:14:10 AM »
The wheel off any pre-1985 R65 will fit. I also have a very bent front wheel and I was loathe to have it straightened again as it has already been re-worked twice and then damaged again.
I bought a front wheel from a German seller and found that the cost of the wheel plus post by DHL was significantly less than the only wrecker I could find in Australia with a wheel wanted for his wheel with post still to be added. From memory I paid about $AU75 for the Wheel and $AU80 to have it posted to me.
It's a shame you are not in Australia as I will shortly have a surplus r65 front wheel as I am in the process of fitting a K100 complete front end to my r65.
