Author Topic: LS Dash pad fix, broken tabs  (Read 1279 times)
Offline wilcom
« on: March 26, 2018, 06:29:34 PM »
I broke the remaining tab off my LS dash pad while installing bars and hand guards. ( 1 step forward, 2 steps back :-[)
I checked all resident fix's here on the site and searched the web. There was a couple of fixes that used Velcro, but for the life of me I couldn't see any place there were mating surfaces to use velcro.
I fashioned the following fix and it is nice and tight and is not going anywhere, at least at R65 speeds, it isn't going anywhere.
I made a wedge out of aluminum and formed it to the contour of the headlight shell. I then hammered/bent the tabs down until it fit the wedge formed by the headlight and the fairing. I used 3M hook & hook(much more ridged than hook & loop)  tape on both sides of the wedge and it seems to hold down the front of the fairing quite well.
It will take a second try to make it better. as you can see from the final pic there is a gap around the headlight where fairing doesn't set down tight enough. A little alteration to the design and placement should cure that. For now, it's secured and I can ride. Perfection is for another day, but it looks like I'm going in the right direction. Hope the pics gives a clear pic of what I did.
« Last Edit: November 09, 2020, 10:51:47 PM by Justin B. »
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Offline mrbuck
  • i luv msbuck
Re: LS Dash pad fix, broken tabs
« Reply #1 on: March 26, 2018, 09:33:45 PM »
A+ on the repair.
« Last Edit: March 26, 2018, 09:38:07 PM by mrbuck »
1981 R100
1998 Laverda 668
Lifan 150 cc Dirt bike
1976 Datsun 280z
1976 Datsun 620 pickup
« Reply #2 on: March 26, 2018, 09:39:32 PM »
Slick!
Offline skippyc
« Reply #3 on: March 27, 2018, 04:29:36 PM »
Good old ingenuity has not been lost. Good job.
