Author Topic: Electrical Gremlin  (Read 3431 times)
Offline Matt Chapter
  • <insert witty remark here>
Electrical Gremlin
« on: March 21, 2018, 11:41:35 AM »
For a while now, my instrument lights haven't always turned on when I start my R65.  This was perplexing, but ultimately of no concern... until I realized that my tail light was doing the same thing at the same time.
All other electronics seem to be fine (my turn signals are out of commission, but I know where that problem is).
What would be the likely culprit? Loose ground?  I'm just speculating until I find time to get in there...
'04 R1150 RT ~41000 miles
Re: Electrical Gremlin
« Reply #1 on: March 21, 2018, 02:25:30 PM »
Run a quick jumper between the triple-tree and the frame, if the lamps come on then run a permanent ground.  The instrument cluster only gets a ground through the through the steering head bearings, IIRC...
« Last Edit: March 21, 2018, 02:26:23 PM by admin »
« Reply #2 on: March 21, 2018, 05:48:54 PM »
Replace the Fuse holder assembly with a modern Spade type
Also Could be the ignition switch
They are the only things common with both
You park light is more than likely out also
« Last Edit: March 21, 2018, 05:57:31 PM by Mrclubike »
« Reply #3 on: March 21, 2018, 05:52:07 PM »
tail light is doing the same thing
They both have ground wires that go back to the main grounding lug near the voltage regulator
« Reply #4 on: March 22, 2018, 10:54:16 AM »
I think I have the original ignition switch, so that could be it.  Also it's been a while since I've cleaned my fuses! I'll have a look.
« Reply #5 on: March 22, 2018, 03:46:17 PM »
I would bet on the fuses.
Try to replace them... You'll be surprised.
« Reply #6 on: March 22, 2018, 05:39:29 PM »
You need to get someone to give you a "gremlin bell". (Bad luck to buy your own). Legend is the tinkling of the bell drives the gremlins crazy and hurts their ears causing them to fall off you bike and become potholes instead.
« Reply #7 on: March 22, 2018, 07:54:14 PM »
This is plug and play
you just have to mount it and your fuse issue is  gone
Offline wilcom
« Reply #8 on: March 22, 2018, 08:02:31 PM »
Ya think that's real, Marc..... I had a cousin and her husband that had a bell on every bike they ever had. I never gave it thought til now
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Offline BPT
« Reply #9 on: March 22, 2018, 09:34:10 PM »
I knew about the gremlin bells from the Harley guys and thought it was mostly an HD thing.
But when I went to the memorial for Perry Bushong (local shop owner), everyone who rode in the procession got one, it was 90% BMW.
Offline BPT
« Reply #10 on: March 22, 2018, 09:37:47 PM »
MrClubike - I think we've discussed your fuse box previously, but it's been a while.
Do you have that strapped to the tube above it?  Are those screws attached to part of the box or does that have something to do with its attachment?
Offline peteremc
« Reply #11 on: March 23, 2018, 05:07:16 AM »
I'm pretty sure the gremlin bell is plug & play as well
peteremc
« Reply #12 on: March 23, 2018, 09:36:20 AM »
I have a gremlin bell, it's on my desk!  Keep my laptop running in top form.
