Author Topic: Stiff (seized?) steering stem bolt  (Read 952 times)
guitardad
« on: November 23, 2007, 11:43:12 AM »
Next project on Hans, the '79 R65.  I'm down to a single assembly to remove from the frame - the steering stem with upper and lower triple clamps.  Problem is I can't get the steering stem bolt to move!  This is a large diameter bolt, with a 10 mm Allen socket in it.  I've been soaking it with penetrating oil, have tried heat (with a propane torch!) and a 2-ft breaker bar with no success.  Any other ideas?
(Oh, and if somebody tells me that this bolt has a left-handed thread, I'll just slink quietly off, thank you very much!)
Re: Stiff (seized?) steering stem bolt
« Reply #1 on: November 23, 2007, 02:12:28 PM »
No, regular threads so no slinking required.  It's just tight but I would have thought a 2' breaker bar would have busted it loose.  I suppose you could hit it with an impact wrench, some shock often works wonders.  If no impact wrench maybe smack it squarely with a hammer a couple of time while leaning on the wrench...
guitardad
« Reply #2 on: November 23, 2007, 04:40:22 PM »
Heat on the triple clamp, then an ice cube on the bolt did it.  Helped to know I was twisting the right way!
« Reply #3 on: November 23, 2007, 04:56:34 PM »
Cool, although it's more fun to switch to a bigger hammer!  ;D
Glad you got it out...
