Author Topic: Vacuum Port on Bing 64/32/335 & 6  (Read 2279 times)
Offline jp9094
« on: January 22, 2018, 01:06:31 PM »
Having bit the bullet and replaced the defective Butterfly axle and "O" ring on the left side carburetor I found myself struggling to set the idle and balance the carbs.
After much to-ing and fro-ing, I  seem to have set the idle mixture (3/4 turn) and set the idle to 1250 RPM (per the tacho).
However I was thinking of trying to balance the carbs with some kind of manometer, but cannot seem to find any vacuum ports on these Bings. I have read somewhere that all the post '80 Bings have ports, but I do not seem to see them.
Am I going blind? Do I need to buy some ports from the Bing Agency and retro fit them??
Any and all help appreciated. Many thanks in advance.
Re: Vacuum Port on Bing 64/32/335 & 6
« Reply #1 on: January 22, 2018, 01:38:49 PM »
If you have them they should look like this. The vacuum port is the nearest stub on this right hand carb. On a left hand carb the vacuum port will be on the inside of the mixture screw instead of the outside.
« Last Edit: January 22, 2018, 01:44:48 PM by bhodgson »
« Reply #2 on: January 22, 2018, 07:23:59 PM »
You have to  watch the   balance  of  the carbs at the same time  you  set idle speed
« Reply #3 on: January 23, 2018, 04:08:43 AM »
Nice one.  I've saved the picture.
What did you edit with ?
Offline jp9094
« Reply #4 on: January 23, 2018, 11:11:35 AM »
Many thanks. As we used to say "Down Under", Problem Solvered!
« Reply #5 on: January 23, 2018, 07:15:23 PM »
FastStone
it is free
« Last Edit: January 23, 2018, 07:17:47 PM by Mrclubike »
