Author Topic: Motogadget wiring diagram  (Read 1437 times)
Offline jamestnewsonr65
« on: November 14, 2017, 07:07:48 AM »
It's been on mind for a while and I wanted to redo the wiring on an R80 project that I'm currently renovating, and decided to use an m-unit that I had kicking around.
One thing which I found difficult, was to find definitive information on how to wire it up specifically for a BMW and how to get the charging light etc hooked up correctly.
For this project I wanted to keep all the stock controls for the functions of the bike, but redo the wiring so it is simpler and more robust than the original.
As I couldn't find anything around on the web which looked close to a wiring diagram for the stock BMW airheads, I decided to draw one up and share it. Hope fully it will help someone out.
1981 R65 (box of bits).
Re: Motogadget wiring diagram
« Reply #1 on: November 14, 2017, 03:42:03 PM »
Nice work - what did you use to do the wiring diagram?
« Reply #2 on: November 14, 2017, 05:41:34 PM »
It helps that I’m a graphic designer, and used sketch.
You can trials of it for 5 days. Fairly easy to pick up and all vector based.
Offline guyom
« Reply #3 on: November 21, 2017, 10:20:16 AM »
Hi i installed a M-unit on my R65 1981 two years ago. and keep the controls also..and change the regulator for a RR45. Just remove everything else... head and rear light, put handlebar flashers.. anyway... what do you need exactly ?
Offline guyom
« Reply #4 on: November 21, 2017, 10:21:49 AM »
haha no sorry you did it. i will check with mine ! thanks
