Author Topic: Tachometer Blip And Ignition Switch  (Read 875 times)
Offline BPT
« on: November 14, 2017, 01:46:56 PM »
A few months back I replaced my original coil (with a Dyna) and also the ignition module (from EME).  Since then, I get a blip with the tach needle when turning the key for the ignition.
It never did this before and now does it every time.  I can ignore it but thought I'd pick the great brains here and ask if there'd be a reason for this and if it is indeed ignorable.
             Thanks!
Re: Tachometer Blip And Ignition Switch
« Reply #1 on: November 14, 2017, 03:21:23 PM »
Mine does the same thing occasionally - i have stock BMW coil and no-name Polish Ignition Control Module. But it use to do it when I had a stock BMW ICU too.
i think you will find that there is also a spark firing as on occasion if the cylinders were full of unburnt charge I get a "woof" too.
I am ignoring both.
Offline BPT
« Reply #2 on: November 14, 2017, 04:01:50 PM »
Ok, glad to know it's not unusual.  I just wanted to make sure it wasn't a sign of something that needed to be looked at.  As I said, it never happened before and now it's every time.  I thought I'd mostly taken care of my electrical weirdness and didn't want to have to chase any of that again.
     Thanks.
