Author Topic: A nice modification  (Read 1840 times)
Offline DonC
A nice modification
« on: June 29, 2017, 07:54:55 AM »
I did this modification a while back and thought someone might like it. The footpegs on all old airheads are staggered and it started to bother me. After doing this mod I feel more symmetrical while riding, if that makes sense. All that is involved is cutting a section out of the left footpeg mount to match the right side then welding back together, then you must lengthen the shift rod an equal amount. See pictures.
Offline DonC
Re: A nice modification
« Reply #1 on: June 29, 2017, 08:01:40 AM »
Photos show:
#1- New footpeg location seem from above.
#2- Completed mod.
#3- Amount removed
#4- Center stand folded up and still accessible.
« Reply #2 on: June 29, 2017, 10:38:39 AM »
Very nice!  Year ago I thought about doing something like this, but being lazy kept putting it off until it didn't bother me anymore!
« Reply #3 on: June 29, 2017, 08:48:18 PM »
Can we see some pictures of you Mikunis
I have been thinking of getting some but have not been really happy with the way the adapters look.
How do you like them in the colder temps (40 deg F)
Offline DonC
« Reply #4 on: June 30, 2017, 08:18:05 AM »
The Mikuni's make the bike more responsive to throttle over the Bing CV's. I do remember I had to do a little modifying to the rubber adapters, I think I had to shorten them. I see you are a mechanic so you should have no problem. My bike is an '86 mono shock. Starting and riding in 40 deg. and lower is no problem.
I got my carb kits here as he'll help you with jetting:
http://www.rockypointcycle.com/c-bmw12_mikuni_carb_kits.html
Offline DonC
« Reply #5 on: June 30, 2017, 08:19:27 AM »
Oops...wrong photos!
« Reply #6 on: June 30, 2017, 05:53:00 PM »
Thanks for the pictures
especially the one without the hoses installed so I could see just how much difference their is in the diameters
They don't look bad at all
Offline tunnelrider
« Reply #7 on: July 02, 2017, 02:29:30 AM »
As Mrclubike said, they don't look bad at all DonC.  A friend put Mikuni's on his R80 and is pleased with them too, although he said he can't give the twist grip a full what-for 'cause it stalls the engine.  I haven't had a ride on it yet but he thinks giving a big squirt on the throttle may dump too much fuel into the chamber without extra air to combust it.
Offline DonC
« Reply #8 on: July 02, 2017, 08:02:26 AM »
TR,
I kept the original size venturis, 32mm, when I went to the Mikunis. I can quickly roll the throttle wide open and it will take it, no stalling. Did your friend go with bigger carbs?
Offline tunnelrider
« Reply #9 on: July 06, 2017, 01:11:01 AM »
I'm not sure what size he went for DonC, but I do know they were flat slides, which I don't think yours are? Sorry my knowledge of carbs is pretty limited.  I'll ask him next time I see him.
