Author Topic: Valve (engine in general) maintenance ?  (Read 3644 times)
Offline guyom
« on: June 19, 2017, 01:48:28 PM »
Hi guys, i read a bit on valve clearance.. and to be honest i am good for electricity or external stuffs.. but i do not good in term of engine... so just standard question (got a 1981 R65) :
1- except the mixture check, oil and oil filter... carb adjustment, do you do some maintenance in the cylinder...? valve ?
2- it sounds that my bike, on the left side, "clic clic clic" more in term of sound that the right part. What can it be ?
Some screws to check ??
Thanks for time
Guillaume
Offline guyom
Re: Valve (engine in general) maintenance ?
« Reply #1 on: June 19, 2017, 02:25:13 PM »
also do you all have a torque wrench in your tool box as an essential tool to have ?  i checked a tutorial on valve clearance and never do anything on my bike since 3 years... well roughly 3000 kms...
« Reply #2 on: June 19, 2017, 03:58:10 PM »
You need to perform a valve clearance check on a cool , warm to the touch engine, an engine that has not just been run .
It would be good idea to check the torque of the cylinder head nuts, before you start the clearance check seeing as you are not the original owner and who knows what was done to the bike before you got it .
So you are going to need a torque wrench .
Here's a youtube video on how to adjust valves on an R100 .
Warning, the language is ' colorful ' at times !!!!!!!!!!!!! ;D
https://www.youtube.com/watch?v=VExx_2kIc9c
I have an '81 R65, original owner, the '81 model year airheads were the worst for valve recession .
I had the heads rebuilt at 45,000 miles, around 73,000 km .
The exhaust valves were close to failing, they were worn razor thin at the contact area with the valve seat .
« Last Edit: June 19, 2017, 04:04:38 PM by Bob_Roller »
« Reply #3 on: June 20, 2017, 03:15:25 AM »
Hello !
As you are new to engine tune-up, here is the procedure I follow at every oil change which is 5000 km because I mostly do commuting in a mildly hot climate with a lot of in town traffic.
First of all start with a cold engine which has not been run for at least 8 hours and below 30 °C (which could be difficult to achieve in some place)...
Check and set valve clearance (and note the value found when checking in order to see if there are valve recession).
Check ignition timing (and dwell if using points) and eventually change the plugs.
Go for a ride to warm the engine.
When back in the shop balance the carbs and adjust idle mixture.
And do the oil change with the oil warm.
The main thing to remember is that you MUST adjust the carburetors on a sound engine (valves properly set, proper ignition, ... ) otherwise you will be doing crap work...
For me it is a routine and I could do this eyes closed, almost. ;-)
« Reply #4 on: June 20, 2017, 03:41:24 AM »
Georges method is a good one and will get the job done. Having a routine makes for a slick operation.
My service routine has one difference. I now do the valve clearance on a warm engine. For safety not hot enough to cause burns  but only cooled for 30 mins from the engine having been hot to drain the oil. There is no need to do valve clearances on a stone cold engine as the gaps will not change to any degree that you can measure. If any one doubts that try setting them warm and check again when the engine is stone cold.
I'm only a relatively recent convert to this method and spent 40 years religiously doing them stone cold. Not That I ever used dealer servicing but do you think they ever did them stone cold.
Offline BPT
« Reply #5 on: June 20, 2017, 12:13:50 PM »
Barry - are you saying that there's some benefit to doing the adjustment slightly warm? Or just that it's not necessary to wait for a complete cool down?
Offline guyom
« Reply #6 on: June 20, 2017, 01:41:43 PM »
hey guys ! thanks a lot... so as mentioned, i have a 1981 R65.. so the worse for clearance ;-) and not the origin owner..  so yea clear..  i will buy a torque wrench and to a check up... ! Thanks for time and advices !!!
Guillaume
Offline guyom
« Reply #7 on: June 20, 2017, 01:54:53 PM »
just a short question on torque wrench  : i easily found 2 models :
1- torque range = 50-250 foot-pounds (70-340 Nm)
2- torque range = 50-250 inch-pounds (6-30 Nm)
but if i am right, torque of the cylinder head nuts are 25Foot-pounds x 1.356 = 34Nm
I am not in the range of both... so considering the price of a torque wrench... which one you choose to buy ?
Thanks for time.
« Reply #8 on: June 20, 2017, 02:05:04 PM »
Whoever wrote "50-250 foot-pounds (70-340 Nm)" wants you to pull head stud threads!
I torque to 20 lb/ft which I think is about 5 lb/ft shy of max.  I always err on the light side as I have no desire to do a block thread repair!  :o
« Reply #9 on: June 20, 2017, 04:14:25 PM »
Neither of the two torque wrenches are really suitable for airhead use, you want one in between the two.  A typical 3/8" drive wrench would be something like 10 - 80 ftlbs and that would cover most needs.   Anything with a bigger range wouldn't be accurate enough for the head nuts.
« Reply #10 on: June 20, 2017, 05:34:49 PM »
I have a nice 3/8" drive "antique" SK beam type which is perfect for these light jobs...
« Last Edit: June 20, 2017, 05:35:09 PM by admin »
« Reply #11 on: June 20, 2017, 07:39:38 PM »
Ideally you want to use most torque wrenches somewhere around in the middle of its range, say, 25% - 80% for best accuracy.   So, keep a lookout for something like an 80 foot pound or no more than 100 foot pound wrench for most uses
« Reply #12 on: June 21, 2017, 08:25:17 AM »
Hello !
I'll compound all what was said above :
You need two wrenches. One in the 5~40 Nm range for the heads and stuff like that and another one in the 50 ~ 200 Nm range, the high figure being used for the output flange nut on the tranny.
Buy good quality torque wrenches because the cost of repairing a failed stud due to incorrect torquing is wayyyy more that the cost of a good quality tool...
Offline guyom
« Reply #13 on: June 21, 2017, 09:02:53 AM »
Hi guys, thanks for advises. Just a last question : consensus for valve clearance for a R65:
0.004" inlet and 0.008" exhaust so 0,1mm and 0,2mm
Correct for all you?
« Reply #14 on: June 22, 2017, 07:09:11 AM »
It's really not that important give or take one or two thou and BMW even changed the guidance 2 or 3 times  but .004" and .008" is what they finished up recommending. It's what most people use.
What is important is consistency of technique so that you get both cylinders as close to the same as possible.
