Author Topic: Clicking noise in Carburator  (Read 732 times)
Offline badgertom
« on: April 06, 2017, 06:30:38 PM »
I noticed a clicking noise in the left cylinder. With an increase of the rpm the clicking noise increases as well. I assume the noise comes from the valve (opening and closing). Before I open open everything up what could possibly be loose? I believe the last time I adjusted the valves I tightened everything. What else could it be?
Re: Clicking noise in Carburator
« Reply #1 on: April 06, 2017, 08:01:34 PM »
A missing needle roller in the rocker is always a good suspect - if it did prove to be that you will need to build a jig to press the old bearings out and the new ones in - not a difficult job. The other source of rattles and clicks is wear in the carb body where the butterfly spindle seats - You used to be able to buy oversized spindle kits which allowed you to simply ream out the worn holes to the right size but I have not seen them for a long time. a really loose one can kick up quite an annoying racket.
An exhaust leak can sound remarkably metallic as can a pinhole head gasket failure.
