Author Topic: Air injection system?  (Read 2743 times)
Re: Air injection system?
« Reply #15 on: November 06, 2007, 08:39:25 PM »
That is freakin' bizzare!  Is it possible that the "solid" one has something stuffed in there that has kinda welded together with carbonm, heat, rust, etc?
« Reply #16 on: November 10, 2007, 10:39:51 AM »
Neat! I'm sure you have run across defective hardware in the past ie screws without threads or a slot machined in them. I just wonder if you have a fitting that was never drilled from the factory! Very odd indeed!
guitardad
« Reply #17 on: November 10, 2007, 11:10:03 AM »
Yeah, I thought it was weird, too.  I scratched thru the thin coating of carbon, and sure enough, it's solid!
I was surprised how easily they came out, and how easily the exhaust nuts came off.  I used a propane torch to heat the nuts up a little, and they spun off with no binding or galling at all.  I used just enough heat until the intake side of the head felt barely warm to the touch.
tagordon
« Reply #18 on: November 10, 2007, 11:16:16 AM »
guitardad thanks for the post.
Very interesting, indeed.
