Author Topic: Removing starter motor  (Read 981 times)
Offline BooG
« on: April 01, 2017, 07:26:35 AM »
I'm sure someone has some wisdom about this....
I am removing the starter motor for an overhaul, and I have removed one allen bolt holding the right side of the starter. The one on the left however.....! How on earth do you get a socket onto the bolt, given the proximity of the casing? Even the allen bolt end is a challenge. It is of course, achievable....but how??!  :-/
BMW R65 1980.
Vespa Sprint Veloce 1971
BMW K75S 1987
Re: Removing starter motor
« Reply #1 on: April 01, 2017, 10:39:16 AM »
It's been about 9 years since I removed a starter , I think I placed a flat blade screwdriver in there to prevent the bolt from turning.
« Last Edit: April 01, 2017, 10:40:43 AM by Bob_Roller »
« Reply #2 on: April 01, 2017, 04:36:51 PM »
I've done a number of these over the years but I can't visualise the problem you are having. A photo might help.
All I can say is that BMW cunningly designed the STANDARD system so you can just get necessary tools onto various things, if a PO has changed the bolting, you mayy be in a world of hurt.
