Author Topic: Battery removal?  (Read 1498 times)
Offline Oconner
  • Sunny So Cal.
Battery removal?
« on: February 03, 2017, 04:06:41 PM »
Any hints on getting the battery out? I can only get it up a few inches and then hits the frame. What am I missing?
Gracias
'82 r65LS
'72 Honda CL 350
'13 FZ6R
Re: Battery removal?
« Reply #1 on: February 03, 2017, 04:23:53 PM »
Usual problem is the sub frame mounting bolts. I can pull my battery past them at an angle but you can always back them out if necessary.
« Reply #2 on: February 03, 2017, 06:55:28 PM »
In my experience the 1979-1980 subframe is a little narrower than the later model and in addition to the protruding bolts the sub-frame itself makes removal of all but the smallest batteries a bit of a trial. The solution s to put the bike on the centre-stand with a couple of small blocks of wood under the stand and to then remove the bolts and then bear down on the rear of the subframe witht he front wheel secured to the ground - a few other bolts may need to be loosened somewhat - the battery can then be easily removed or inserted.
My experience with y 1984 edition is that the battery can be easily replaced, but bear in mind I have used gel cell batteries exclusively and I suspect that they area little smaller than wet cell batteries.
Offline Oconner
  • Sunny So Cal.
« Reply #3 on: February 05, 2017, 02:51:55 PM »
HA! so I took off the side covers seems PO had zip tied the bugger down and I couldn't see it. Once I cut that off it came out easypeezy! Nice new battery fires right up nice and strong ahhhhh.
'82 r65LS
'72 Honda CL 350
'13 FZ6R
« Reply #4 on: February 05, 2017, 03:35:32 PM »
The bikes originally had two wide rubber straps that held the battery in place, previous owner probably tried this in place of the straps .
