Author Topic: Spraying Plastics  (Read 1130 times)
Offline Adrian
  • The Old Hairy Biker Sez...
Spraying Plastics
« on: November 10, 2016, 12:22:54 AM »
Hi again - I am about to respray the front mudguard - does anyone have any experience/advice about what type of paint to use? What kind of undercoat particularly. I have researched today and I have found two pieces of advice. One suggests standard grey primer that would be used on metal surfaces and another recommends Etching primer - which I'm already using on the seat tray and have used on all the metal parts I have resprayed so far - like crash bars and things.
So any help would be great thanks ...... Adrian :-)
1984 R65 (860)
Re: Spraying Plastics
« Reply #1 on: November 10, 2016, 02:48:53 PM »
https://youtu.be/TuJnjN7QqBc
This might be of some use
Offline Adrian
« Reply #2 on: November 10, 2016, 08:09:38 PM »
Okay thanks for that Chris :-)
1984 R65 (860)
« Reply #3 on: November 10, 2016, 08:18:25 PM »
I have repainted several and I used Dupont Chroma system base-coat/clear-coat paint and so far all is perfect.  I think I used the two part Dupont Uro Prime but not sure it's still available.
AFAIK you don't need an etch primer on plastic - what is there for it to etch?  Etch primer has a bit of acid in it to help bite into a bare metal surface.
« Last Edit: November 10, 2016, 08:20:04 PM by admin »
Offline Adrian
« Reply #4 on: November 11, 2016, 05:38:37 AM »
Thanks Justin :-)
1984 R65 (860)
