Author Topic: 1982 R65LS Brembo's F08's or what  (Read 2247 times)
Offline SoloLobo
« on: August 24, 2016, 12:14:20 PM »
I need to track down some new dust seals for my 1982 R65LS's Brembo front calipers and don't want to have to buy the complete rebuild kit from BMW... just want the dust seals.
Does anyone know the Brembo part number for the LS calipers?  In googling for about an hour I can't find a definitive answer, nor any site that converts BMW parts numbers into Brembo numbers.
I may just take the seals into an auto parts store, but thought I would ask here.  There is some talk on the net that the calipers have a part number stamped on them, but I haven't found that to be the case.
Anyone have any information they can share?
« Last Edit: August 24, 2016, 12:15:01 PM by SoloLobo »
Re: 1982 R65LS Brembo's F08's or what
« Reply #1 on: August 24, 2016, 03:08:04 PM »
Measure the piston size - they will (IIRC) be 36 or 38 mm, then put the size into a ebay search
eg:
http://www.ebay.com.au/sch/i.html?_from=R40&_trksid=p2060353.m570.l1313.TR0.TRC0.H0.X36mm+brembo+dust+seals.TRS0&_nkw=36mm+brembo+dust+seals&_sacat=0
And then pick your poison. (And get irritated at the silly post quotes from US sellers)
« Reply #2 on: August 24, 2016, 04:00:45 PM »
OK, it's a Guzzi supplier but Brembos brakes is Brembo brakes.
Brembo Seal Kit, F08 Caliper  Part Number 14659000  $16.44 IN STOCK
I use these guys. Suggest you call and confirm your needs.
http://www.mgcycle.com/index.php?main_page=product_info&cPath=110_115&products_id=591
« Reply #3 on: August 24, 2016, 04:52:21 PM »
F08's but as Tony said measure the piston because I think they are 36mm rather than the more common 38mm.
« Reply #4 on: August 24, 2016, 09:41:08 PM »
Sorry i just noticed you only want the dust seals
can't recommend that
Anyway here is what i did
If you have a 36mm Brembo caliper
Below  is it on Moto bins
here is it on Max
http://www.maxbmwmotorcycles.com/fiche/PartsSearch.aspx?&searchtype=partnumber&parts=34%2011%201%20454%20807
If I were you I would put the 36 mm on ebay and let some one else repair it
 Then spend the money on a 38  mm F08
http://www.mgcycle.com/index.php?main_page=product_info&cPath=110_115&products_id=1034
then you will have better braking
Plus the brand new caliper comes with new pads  :D
This is the exact caliper i have put on my R65 in place of  the OEM caliper
Then if it needs a rebuild your kit will only cost $16.44
« Last Edit: August 24, 2016, 09:58:59 PM by Mrclubike »
Offline SoloLobo
« Reply #5 on: August 25, 2016, 03:07:10 PM »
The pistons are in fact 36mm, and the dust seal part number is 20.2246.10.
I have a few emails out to see if I can track down the seals.
Won't be going with the new F08's as other than this one seal, my current calipers are fine.
Offline Billmc
« Reply #6 on: August 29, 2016, 09:16:31 AM »
Not to highjack this thread but does anybody know the correct replacement pads and the vendor for the Brembo front caliper on an '87 R65?
I have already bought, and returned, 3 sets of pads that looked right but were too large in overall dimensions,  that the vendors SWORE were the correct ones and would fit. With that in mind, how about the CORRECT rear drum shoes?
Thanks in advance and sorry again about he highjack.
1987 R65 Silver
Offline wilcom
« Reply #7 on: August 29, 2016, 09:44:23 AM »
Bill what part numbers have you received that didn't work?
It's interesting that the RealOEM gives a part number for your 87 that when plugged into Teds Beemer shop site says it's for only up to 85.....hmmmm
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
« Reply #8 on: August 29, 2016, 12:00:07 PM »
The BMW Classic Shop gives this P/N 34 21 7 657 025 for 1986 R65 bike.
For my 1982 R65 with Brembo caliper they gave  34 11 2 301 360 part number and 34 11 2 301 359 for ATE calipers...
I do not know if the Brembo caliper are identical before and after 1984, but I know for sure that the material the disc are made of are different (and  the look too); So maybe the different part number has something to  do with the matching of material  and friction pad...
Hope this helps.
Offline Matt Chapter
  • <insert witty remark here>
« Reply #9 on: August 29, 2016, 02:39:29 PM »
I just went through this process a few months ago.  What I did was measure my correct pads down to the millimeter.  Then I went to the EBC site and paged through their catalog until I found the pads with the correct pin holes and dimensions.  I posted about it here, let me see if I can find the link...
Edit: Here's the thread I started with all the gory details: http://www.bmwr65.org/cgi-bin/yabb2/YaBB.pl?num=1458223928/0#0
« Last Edit: August 29, 2016, 02:47:12 PM by mchapter »
'04 R1150 RT ~41000 miles
Offline Billmc
« Reply #10 on: August 30, 2016, 09:17:33 AM »
Thanks for the info, I will look at those sites and see what I can come up with.
I was using  P/N 34 21 7 657 025 as my reference # and that's what I got from the suppliers, but they were all too large.
I will measure mine and try to match those dimensions.
1987 R65 Silver
