Author Topic: Starter problem  (Read 2035 times)
Offline vtmando
Starter problem
« on: May 08, 2016, 01:24:59 PM »
83 R65...starter turns but seems to not be engaging the engine to turn it over...do I need a new starter or can this problem be repaired? :-[
1982 R65 ?
1973 R75/5
Re: Starter problem
« Reply #1 on: May 08, 2016, 01:28:39 PM »
It can be repaired, sounds like the ' Bendix ' is stuck and the starter gear is not being pushed out to contact the flywheel .
There is a thread in the R65 FAQ section that shows how to disassemble a Bosch starter and lubricate it .
Re: Starter problem
« Reply #2 on: May 08, 2016, 02:09:11 PM »
Also, check out the thread "Battery life and starting question" just a few doors down.
Offline vtmando
Re: Starter problem
« Reply #3 on: May 14, 2016, 01:51:19 PM »
Thanks for the insight guys...I have one last question regarding the battery...could a less than fully charged battery stop the solenoid from properly engaging the starter to turn over the engine? Seems to me that when I have the battery fully charged it kicks right over? I'm thinking to replace the battery before digging into the expense and effort of the starter.
Thanks again...
1982 R65 ?
1973 R75/5
Re: Starter problem
« Reply #4 on: May 14, 2016, 03:09:15 PM »
Thanks again...
Yes.............invest in a battery tender before you replace the battery it will kept it topped up and you may find that you don't need to replace the battery, they are not expensive $20 on flebay.
« Last Edit: May 14, 2016, 03:13:45 PM by Lucky_Lou »
Re: Starter problem
« Reply #5 on: May 14, 2016, 03:26:11 PM »
How old is the battery ???
If you decide to replace the battery, go with an AGM type battery, generic AGM batteries are quite reasonably priced .
Offline vtmando
Re: Starter problem
« Reply #6 on: May 14, 2016, 07:28:31 PM »
Not sure of the battery age...I bought the bike from someone last year. Everything has been fine...rode all last summer and put it on a tender for winter storage. It turns and starts intermittently which has me confused as to which is the problem...battery or starter. :-/
1982 R65 ?
1973 R75/5
Re: Starter problem
« Reply #7 on: May 14, 2016, 09:24:01 PM »
Put a volt meter on the battery during cranking when it isn't wanting to turn over if it goes below about 9 volts you more than likely have a weak battery or possibly a draging starter.
If you have a standard wet flooded battery I would get rid of it and buy an AGM.
AGM batteries normally  do not need a tender
Offline vtmando
Re: Starter problem
« Reply #8 on: May 15, 2016, 11:14:09 AM »
Will do...Thanks!
1982 R65 ?
1973 R75/5
